Results 1 to 5 of 5
Thread: Learner bikes with ABS and R-E test E Stops
    Member DrRockso's Avatar
    Sep 2010
    Perth, NOR
    GSXR600-L0
    4 times
    Hi there,
    With the release of the new optionally ABS equipped CBR250r soon approaching, Is it ok to be tested on your e-stops with an ABS bike?
    The same question would apply to R class bikes.
    I've already got my r-e so just curious about this. I think there is benefit in learning how to front brake properly but the technology is more than welcome on bikes, will the skill become less relevant in the future?
    I guess stopping in 12m is stopping
    in 12m.
    DrRockso.
    Ev
    Ev is offline
    Member Ev's Avatar
    Balga, Perth WA
    CBR250R/CB400ABS
    4 times
    Whatever you ride skill is still relevant, abs wil not prevent stoppies, or flipping it.
    Also when abs activates releasing and re-applying brakes due to poor technique
    stopping distance will dramatically increase.
    abs bike is good to learn on though, as it will help mitigate against any bad attempts at hard
    Braking, rear wheel lockup doesn't occur though and when you move to a non abs
    Bike, you should be aware of this.
    hopefully you should be practicing with minimal rear brake and have no problems adjusting though
    All legit for test centre, good bike to use
    Member thro's Avatar
    Jun 2006
    Wellard
    CBR600RR7, 1.5x VJ22 RGV250
    157 times
    7 Post(s)
    You still need to have the confidence to squeeze hard - the requisite 12m can easily be done without getting anywhere near lockup on any half competent bike.
    stuff
    Member courtz's Avatar
    Oct 2010
    Byford
    ZX6R
    16 times
    10 Post(s)
    I imagine it would be fine, given what is said above plus the fact that cars with ABS are perfectly acceptable for the car license test!
    Member M|ke's Avatar
    Aug 2009
    North Perth
    Decisions Decisions Decisions...
    Well they're slightly different on each bike, they don't all use the same ABS system. But it would be fine, they won't mark you down or anything for it.
