Results 1 to 7 of 7
Thread: Stalls when putting in first gear.
    Apr 2011
    Karawara
    ZXR250C
    Hey guys, my bike stalls when I shift it first gear in the morning, especially if its cold. Only way to get past this is to rev it a bit higher and put it in gear but there's a LOUD clunk if I do this.
    Oil level seems fine. Any ideas would help thanks.
    Member emrys74's Avatar
    Nov 2008
    Westfield
    07 Sprint & 05 Smoto Burg
    102 times
    7 Post(s)
    if you got a cable clutch try adjusting it it might be slack
    Member K1GxR's Avatar
    Aug 2009
    Como
    vee twin
    4 times
    kawasaki??
    fast idle, blip revs a bit, and keep pumping the clutch.. pump hold pump hold ... do this for about 15 seconds.. and when you put in first gear she'll go fine.
    alternatively, a barnett clutch fitted up will solve this altogether. it's not really a problem, more a quirk of a kawasaki.
    Member I Fancy Holidays's Avatar
    Jun 2010
    Lesmurdie
    CRF450R Supermoto
    107 times
    ^^^ WFS
    All the Kawasaki's I've ridden have had clunky gearboxes. :S
    upg
    upg is offline
    Member upg's Avatar
    Jan 2007
    GPX250
    while your at it also check the side stand switch
    Apr 2011
    Karawara
    ZXR250C
    I'll check the clutch cable when I get back and see.
    @FEARLEZ5
    Yes it's a kawasaki! I'll try it out tomoro morning. Thanks
    Member thro's Avatar
    Jun 2006
    Wellard
    CBR600RR7, 1.5x VJ22 RGV250
    157 times
    7 Post(s)
    clutch drag.
    as fearlez5 said. i had a zzr that did it if not from new, within a few months of being new....
    stuff
