Results 1 to 3 of 3
Thread: VTR 250 not starting well.
    Feb 2011
    Success/Cockburn
    Bike was not used for 3 weeks and now does not start so well. Only does after a few dozen tries. Just clean the spark plugs or is there anything else to check out?
    Member Frogger's Avatar
    Nov 2009
    Port Kennedy
    21 times
    check the battery and give it a good ride to clear the carbs abit. u might have got fuel varnishing in the carbs so your passage ways are half size or so. when it starts u could run it then stop and check the plugs to see if its running lean.
    Member falcon's Avatar
    Nov 2010
    Hey mate, get yourself a copy of the VTR250 workshop manual if you don't already have one:
    http://www.timdoyle.net.au/pdfs/VTR2...hop_Manual.pdf
    Should help with diagnosing any problems.
