F#@$ing hyosung...
While I exited the freeway I pulled the clutch lever and noted that it went soft. I had to pull the lever almost all the way for the clutch to work. I rode the bike home carefully and guess what? ...when I got home, the clutch cable snapped. Luckily it didn't happen while I was booting it on the freeway.
This raises a couple of questions for beginners who didn't have to deal with these sort of issues... yet...
What would the best way be to handle the situation where your clutch cable snaps while you're on the freeway going at "high speed"?
(1) Slow down until you're within the optimal rev range to downshift, and gradually downshift (without clutching obviously) while you slowly pull left and kill the engine in the last minute (to avoid clogging the sparkplugs if you kill the engine while you're still at high speed)?
(2) Don't bother downshifting and just apply the brakes gradually and pull left and kill the engine sometimes in the process or let it die?
(3) If possible, continue riding carefully until you get to the exit nearest to your home and then slowly pull over and kill the engine as described above?
(4) Any better way to deal with the situation?
The second question is, if you are stuck in the middle of the freeway ...what do you do? I assume staying with the bike while help arrives is too risky. Should you leave your bike on the side of the freeway and climb/jump over the fence and wait on the safe side? (assuming that the nearest exit is too far to push the bike)
Cheers!
Ervin
