Page 1 of 2 12 LastLast
Results 1 to 20 of 21
Thread: ZXR250C Carby "misc hose with screw stuck in it"
    Apr 2011
    Karawara
    ZXR250C
    Hi, I've recently stripped my airbox to check on the carbies if they were dirty. All 4 of them looks clean however I found an "extra hose" hanging down with a screw in it?
    Im not too sure what this hose does, Can any1 sent me a photo of their carbies and where the hoses are meant to be?
    I will post a picture later when I get off work.
    Member =Stevo='s Avatar
    Oct 2005
    Como
    33 times
    Vacuum/suction hose to the airbox? Is the screw sealing the hose off?
    Apr 2011
    Karawara
    ZXR250C
    Im not 100% sure, my first time stripping it. it was kinda dark at that time as well, seemed to me it was coming from the carbs it self.
    I've pulled out the screws, doesnt seem like a fuel hose cos it was dry and no sign of liquid..
    Im thinking it might be the vacuum/suction hose but where does the hose suppose to go?
    Moderator Barfridge's Avatar
    Feb 2005
    ZX-7R
    822 times
    52 Post(s)
    Some bikes have a spare vacuum hose off the carby that you can plug a vacuum gauge into. Of course this will need to be plugged when not in use, hence the screw.
    Member milesiles's Avatar
    Feb 2010
    Perth NOR
    2011_Honda_CBR1000RR_Fireblade
    29 times
    Yeah jamming a screw/ bolt into a non essential vacuum hose is standard practice. The screw didn't just end up in there, someone has taken the time to make that killer mod, just have blind faith that they had some idea what they were doing, and roll with it.
    I used to have a nice sig offering to shadow ppl. Now I have no sig...
    Apr 2011
    Karawara
    ZXR250C
    I just noticed aswell when i start my bike without the airbox, when i throttle it, only the right carb seem to work(blows air and slider moving up). is it normal? I have no experience in this.
    Apr 2009
    Walliston
    Pumba
    408 times
    11 Post(s)
    All carbs should open and look the same when you open the throttle. Is performance down?
    Member Frogger's Avatar
    Nov 2009
    Port Kennedy
    21 times
    all 4 should be the same from what i remember , if u get a picture up it will help.
    Oct 2011
    Corowa
    ZXR250
    I had mine apart today and there should only be 3 hoses coming from the carbs
    1 fuel in pretty obvious
    2 vacuum to the tank petcock or fuel tap comes from the bottom of the carbs
    3 Vacum to the top of the air box 2 hoses coming out the top of the carbs with a T piece into 1 into the airbox
    Aug 2011
    Do you have a 4 cylinder zx250???
    Apr 2011
    Karawara
    ZXR250C
    No, mine's a 4 cylinder zxr250c
    Question guys,
    I just recently removed my pilot screw, I noticed there's washer, o-ring, and the screw, but I've seen youtube video's and the manual showing a spring in it.
    Is the spring really necessary? and in which order should i put it back in? Spring - washer - o ring - screw? or washer - o ring - spring - screw?
    Oct 2011
    Corowa
    ZXR250
    This any good to you
    Apr 2011
    Karawara
    ZXR250C
    yeah I have the same manual, thanks steve.
    I don't have the springs
    Jul 2011
    West Side
    '92 ZXR250
    Quote Originally Posted by Stevezxr View Post
    Hey sorry loonggan cant help you there but did you get manual off internet (pdf file) or ??
    If so can I get it off ya or download it somewhere? (looked around and wasnt as easy as I thought, preferably 92, Ive got a 97 shit one)
    Sweat wipes off, road rash doesn't. Make up ur own mind, it's a free country.
    Oct 2011
    Corowa
    ZXR250
    I have the shit one of the net .pdf and about 10 pages from the parts manual for both the A and C model
    Just check my other posts they are all posted here for download
    Jul 2011
    West Side
    '92 ZXR250
    I cant check where u have posted, only in the areas where u have posted i.e. two fiddy section.
    quick search I cant find it on here?
    Oct 2011
    Corowa
    ZXR250
    Jul 2011
    West Side
    '92 ZXR250
    ahhh cheers bro
    Apr 2011
    Karawara
    ZXR250C
    Hey guys, does your bike idle well when cold? Mine seems to stall if I dont hold the throttle. After when its warm it seems fine.
    I've cleaned the carby, new battery, air filter, spark plugs, even adjusted the pilot screw to 3 turns! and adjusted the idle screw!
    Aug 2011
    If it is what I think it is. It goes washer spring screw. The washer separates the spring from the screw and just keeps tension on the screw so it does not turn on its own
