Results 1 to 6 of 6
Thread: Front Doors
    Member MadDocker's Avatar
    Oct 2008
    Canningvale
    Honda VTR250
    15 times
    Front Doors
    Hi everyone,
    On Monday night, our front door was damaged and we need a new one.
    Does anybody out there sell front doors or have any contacts?
    Cheers,
    MadDocker.
    Administrator Brougham's Avatar
    Aug 2004
    PSB Sweatshop
    359 times
    64 Post(s)
    Solid front doors?
    Bunnings do them cheap, but you need to paint, fit and put lock on yourself.
    Doors Plus / Doors and More both will fit, paint/stain, and put locks on for you.
    Oct 2008
    Canningvale
    Honda VTR250
    15 times
    Yeah solid front door.
    I can paint and fit locks no problems. How hard are they to hang?
    Aug 2004
    PSB Sweatshop
    359 times
    64 Post(s)
    very easy.
    you need a planer normally, as the doors are a few mm bigger to allow for discrepencies. then just a wood chisel (or router) to notch out for the hinge depth, and screw it on.
    quite simple.
    Member shmoo's Avatar
    Christchurch, NZ
    455 times
    16 Post(s)
    also help if you have another pair of hands to hold the door whilst you line up the hinges with the wall
    a good tip i used was to have a couple of those rubber wedge shaped door stops handy. You can use them to support the door at the correct height, saving you from having to try and hold it perfectly in line.
    Refugee and Humanitarian Issues: Australia's Response
    *Department of Immigration and Citizenship*
    There is no offence under Australian law that criminalises the act of arriving in
    Australia or the seeking of asylum without a valid visa.
    Member Desmo's Avatar
    3387 times
    265 Post(s)
    Quote Originally Posted by shmoo View Post
    You can also use them between the door and the frame near the hinges to "tweak" the hinges if it doesn't hang quite right.
