Results 1 to 11 of 11
Thread: HELP!
    Member NanoBear's Avatar
    Jan 2007
    Fremantle
    Suzuki Intruder VL250
    49 times
    Woke up this morning to find my computer refusing to turn on. Everything powers up in the box, but no power to keyboard and mouse, and no output to monitor, not even the gfx card test. There's also no beep code from the mobo, so my assumption at this stage (having tried different RAM sticks and HDDs) is that either the gfx card is dead or the mobo is dead.
    Would really appreciate any learned opinions. Thanks.
    setup:
    Asus 8AN-E
    AMD X2 4200+ (stock speed atm)
    2GB Mushkin DDR400
    Seagate 300GB SATA 2
    Leadtek GeForce 7800GT
    Top end 750W PSU (can't remember the make of the top of my head)
    DVICO TV card♠
    Member TYSON's Avatar
    Apr 2004
    Sweatshop
    Turbo Hayabusa, 06 GSXR 1K, 09 700 Raptor SE
    Has it got an onboard graphics card? try removing the GeForce and plugging the monitor cable into that.
    My Turbo Build
    Thanks to Sponsors:
    Motorcycle Panel & Paint
    Q-Zar Fremantle
    Rated-R Parts
    Carpet Liquidators - Midland
    Member Aphex's Avatar
    Nov 2006
    A private road
    One thumps the other screams
    ew...
    UPS ftw.
    Lightrning FTL
    Quote Originally Posted by IPIT on relationships
    Jan 2007
    Fremantle
    49 times
    No onboard gfx. Haven't tried another gfx card yet, have to borrow the neighbour's. That comes tomorrow on my light uni day. Reasonably sure it wasn't storm damage, although I suppose I can't be sure. Praying like hell its the gfx and not the mobo. Then i can go get a dx10 card instead of hunting down a very ellusive socket 939 mobo
    Member D'Artagnan's Avatar
    Aug 2006
    Somewhere between Perth and Cairns
    Benelli TnT CR 1130
    58 times
    Rip everything out and try again. Add one thing at a time if it works. If your not getting POST beeps, chances are it's the mobo or atx power circuit.
    Jan 2007
    Fremantle
    49 times
    was planning on doing that tomorrow in daylight, but then remembered getting some interesting errors from the TV card recently. Yanked it and now all is good. Seems faulty tv card was stopping absolutely everything else from working.
    Member BIGFELLA's Avatar
    PERTH/WANNEROO
    1999 R1
    Do you have a 56k modem???? When there is a electrical storm the modem can get zapped and from then on your box will not post,take out modem card and try to fire up.
    BIGFELLA SAY'S " make love,not war. Get married have both.........."
    Member Dingo's Avatar
    Mar 2005
    Crumpys Jawa
    Whippersnipper, Superhawk, Mini-Fighter, Bali Harley
    Defintley sounds like a victim of a power surge, youll need to replace modem as the BIGFELLA said or the power supply.
    Dad lost a whole home office full of equipment once because he forgot to use a surge protector.
    Feb 2004
    back of beyond
    1098,xjr1300,525 tard
    44 times
    slightly off topic, but with todays day and age of every room having expensive gadgets, isnt there a surge protector you can get for your whole house?
    -J-
    -J- is offline
    Member -J-'s Avatar
    5 times
    Dad lost a whole home office full of equipment once because he forgot to use a surge protector. [/b]
    bet its the power supply
    'When one person suffers from a delusion, it is called insanity. When many people suffer from a delusion it is called Religion.' - Robert M. Pirsig
    Member PolishDude's Avatar
    Nov 2005
    SOR
    ZX10R SE
    i wouldn't put the graphic card in ... if the 1st one burned then the 2nd one will ... , check for LEDs on the motherboard or something, yeh like other say power, u'd have beeps for wrong ram, u took out the HD, the HD can freeze whole pc, if u confused master/slave with other devices, easily done ... no beeps / POST
    check the power supply with the volt meter? (the output on the motherboard ...) check the fuses, in the power supply ...
    good luck
