Results 1 to 4 of 4
Thread: Larger Capacity Laptop Batteries
    Member remand's Avatar
    Mar 2008
    My new laptop chews through it's battery and i'm looking to get a secondary as a backup at uni etc.
    I'm wondering if anyone has bought any generic one's from what seems to be thousands of websites or fleabay etc and how they hold up compared to the genuine versions from the actual laptop manufacturer.
    The laptop in question is a dell studio 1557 i7 720qm.
    Quote Originally Posted by TurboR1 View Post
    Herpes. Nature's sherbet.
    Member ocusa's Avatar
    Mar 2007
    Mt Lawley, Perth, WA
    1991 Suzuki RGV 250
    I bought one for an older model a few years ago. Worked fine for me. Try to buy from someone who specializes in batteries if you can.
    Domokun!
    Member taboo_'s Avatar
    Feb 2007
    Middle Swan, NoR
    Goodbye '98 CBR900RR. You will be sorely missed. HELLO '08 CBR600RR ^_^.
    I've bought multiple batteries off eBay for lappys before. Laptop batteries have a tendancy to die VERY quick - it often has to do with leaving the battery in while having it plugged into the mains.
    I've never had a problem with the generic ones on eBay and have never paid over $30 for one. What you want to do is find one that fits and get one with the highest amount of mAh - the higher the mAh the longer it'll last on full charge.
    In case you don't already know when you run off your battery you want to set up a power profile in windows that steps your CPU down (so it's not chugging away at top speed) and also drop your screen's brightness all the way down - doing that'll help A LOT.
    -taboo_
    Listen to our podcast - SCREAMING IN DIGITAL. Or help us spread the word by liking our Facebook page.
    Contact me for any home I.T. help or if you're planning on building a PC. I'm good at what I do .
    Feb 2007
    Middle Swan, NoR
    As I kind of mentioned you also want to avoid having the battery in while it's plugged into the mains - unfortunately this means if you bump the power cable or have a black out your lappy will just die but it will help the life of your battery.
    And if you also mainly use your lappy plugged in OR it'll go through lengthy periods where it's not getting used at all (summer holidays) you want to store the battery at ~40% charge.
    (otherwise just unplug your lecturer's projector and use his 240v's ).
    -taboo_
