Results 1 to 20 of 20
Thread: What will I need for a Lan party?
    Member timmyboy's Avatar
    Oct 2007
    Canning Vale
    YZF1000R
    4 times
    I am thinking of hosting a small lan party (4-10 people) at my place, but it will be the first lan party for my mates and I so am unsure what I will need.
    So lay it on, what will I need?
    I am understand that I will need a switch, which one would you recommend?
    Is it unwise to have a couple of people hook up to one surge protector power board?
    I am unsure what games we will play, but how much of difference would there be having one computer act as dedicated server?
    Thanks in advance.
    Member malenko's Avatar
    Jul 2008
    Noranda
    09 black/green cbr600rr and a GPX
    8 times
    Dedicated server is fucking awesome but not needed, lots of pizza and nachos and coke
    Those surge protector boards are pretty good, just dont put double adapters on each output to get more people on the board, that ends nasty.
    Pretty much any switch/hub will do as long as you have enough ports for everyone to plug into.
    Also make sure you actually have enough room and desk space before people get there and ask what they are bringing. I have seen a few people rock up with a 3x24inch monitor setup to show off their epeen. And tell everyone to bring headphones, I have also seen people their 5.1 setup.
    Quote Originally Posted by browncow View Post
    Sometimes, I see you post, and I understand what all the individual words mean, but I have no idea what you're actually saying.
    Member Desmo's Avatar
    790 times
    54 Post(s)
    Friends.
    Member brandonberg's Avatar
    Dec 2010
    Vic Park
    2007 ZX6R
    A tip - My mates and i used to mark our power/ethernet cables etc with a short length of different coloured electrical tape. It makes it easier to identify who ownes what when cleaning up and avoids any ownership issues.
    Oct 2007
    Canning Vale
    YZF1000R
    4 times
    Cool thanks Malenko.
    Quote Originally Posted by Desmo View Post
    Friends.
    What is this 'friends' you speak of?
    Member SOLID's Avatar
    Oct 2008
    Between a pimp and a hard place
    636 SE
    176 times
    No speakers only headphones is a good rule.
    "Democracy means simply the bludgeoning of the people by the people for the people"
    790 times
    54 Post(s)
    Quote Originally Posted by timmyboy View Post
    People you meet on the WoW forums.
    And yes, a no speaker rule is a good one.
    Also, make sure you have enough HDD storage space......
    Oct 2008
    636 SE
    176 times
    Don't announce that you have porn or the server will crash
    Member Mo-Fo's Avatar
    Jun 2010
    Clarkson
    '09 R1
    97 times
    If you're hosting it then yes, a hub. Otherwise I'm sure someone else will have one.
    Checklist..
    PC
    Monitor
    Mouse
    Mouse mat
    KB
    Headphones
    Any other peripherals (joystick/steering wheel)
    Ethernet cable
    Power board
    Chair?
    Munchies/Redbull/money
    Some good weed (if that's ur thing)
    and if it's an overnighter then maybe a pillow and blanket (just in case you can't go the distance and flake out at 5am)
    790 times
    54 Post(s)
    Quote Originally Posted by Mo-Fo View Post
    You can pick up a gigabit switch for SFA nowadays.
    Essential.
    Member Squawk_Ident's Avatar
    May 2010
    Safety Bay
    K6 Gsxr1000
    So need one of these south of the river. Someone start one K go
    The propeller is just a big fan in the front of the plane to keep the pilot cool. Want proof? Make it stop; then watch the pilot break out into a sweat
    Jul 2010
    Parkerville
    Suzuki Across
    Don't daisy chain surge protected boards. If one surges it dumps its power down to the next board, knocking that one out, and so on, possibly damaging devices attached.
    Daisy chaining non-surge protected boards is usually the way to go when it comes to LANs, but it's best if you can get each person onto a wall socket each.
    Jul 2008
    Noranda
    8 times
    If you have a whole heap of people around try and either spread them out around the house, or run extension leads from power points from the bedrooms too. Houses often have multiple circuits in them. Kitchens, lounge rooms/activity/family rooms on one circuit, bedrooms on another. Balancing your power load over both circuits is handy cos it reduces the chances of overloading and blowing fuses, and if one does overload, it doesn't effect everyone.
    Member Kryzaach's Avatar
    Sep 2007
    Sinagra
    '07 CBR1000RR
    16 times
    DHCP Server.
    Predefined list of games.
    To cut down on downtime, game installs that can be directly copied and run are far preferable to complex installs.
    Someone cluey when things get numptied up.
    A large stick to to thrash the guy who rocks up and decides to rebuild his computer for no reason and fucks it.
    "In all the human societies we have ever reviewed, in every age and in every state, there has seldom if ever been a shortage of eager young males prepared to kill and die to preserve the security, comfort and prejudices of their elders, and what you call heroism is just an expression of this fact; there is never a scarcity of idiots." -The Culture
    Member Pkunk's Avatar
    Wise words from Kryzaach
    How beefy is your home ADSL/modem router combo? I've had 2x4 person LANs where a cheap ass one was good enough... no need for a switch or anything. It even handled the load well when the 4 of us played games online
    If you end up having more people any old switch should suffice but make sure your ADSL gear is up to snuff. Something like the ASUS RT-N16 should do well and might even handle 10 people on wireless all playing online without too much trouble. Less so if you try to leech porn at the same time (which is again, another LAN staple)
    Member McGoo's Avatar
    May 2008
    Couchland
    1991 XT600.
    14 times
    I have some old switches you can have if needed. Note 'have', not 'borrow'. They are commercial grade circa ~2000, somewhere around 30-50 ports on each (there are two of them) rack-mounted noisy beasts. They can do all sorts of wonderful things Im sure, but the only bit you would care about is that they work. Oh, they are only 100Mb though, so not the fastest option. Let me know if you get that desparate.
    Go soothingly on the grease mud, as there lurks the skid demon! Press the brake foot as you roll around the corners, and save the collapse and tie up.
    Member Ferris's Avatar
    May 2004
    BNE
    09 Busa
    14 times
    24 or 48 port gigabit switch
    ethernet cables. but tell people to bring their own.
    x number of powerboards
    x number of table and chairs
    no speakers, only headphones rule
    1 monitor rule
    dhcp server
    dc++ a week before all the leeching directories. everyone must do this.
    uptodate virus scanning a week before. everyone must do this. nothing worse than some cunt rocking up with a pc which has the dreaded lurgy on it.
    enough parking
    Work Buy Consume Die
    Oct 2007
    Canning Vale
    YZF1000R
    4 times
    Quote Originally Posted by McGoo View Post
    Thank you for the offer. Can someone tell me if it is ideal if I get a gigabit switch or will a 100mb switch be fine?
    Oct 2007
    Canning Vale
    YZF1000R
    4 times
    Quote Originally Posted by Ferris View Post
    1 monitor rule
    dhcp server
    enough parking
    Holy shit a 24 port gigabit switch? I aint got that many nerdy friends. I am thinking 10 people tops as per my 1st post.
    Jul 2010
    Parkerville
    Suzuki Across
    If you're leeching off each other gigabit is a must (also look into jumbo frames. Makes shit transfer faster).
    If you're just playing games, 100mb is enough.
