Greetings from Shanghai, China.
I moved here about 6 years ago and found that there are a lot of cool bikes here left over from yester-year. Maybe they come over as junk and then find their way to the road. But I figured I should make use of my idle time and go find some parts and a project bike.
Its about 90% done right now but I wanted to make a thread about it since I have not done a complete build thread to date.
I picked the FZR400 as a frame for its ..well.. Frame design I guess.
I raced one of these before and it was by far the best little handling bike I rode at the time (Circa 1988). So I am partial to it for that reason.
But this bike lacked any balls. Its 400cc margarita blender of an engine was great but not enough umph for me.
So I decided a 600cc FZR engine would work well I started to make plans then read up a bit more and found that a YZF600R (Thundercat) engine is a direct bolt in hmmm
I then found a buddy who donated the engine out of a wrecked YZF600R, he had, to me. The engine had issues but I did not care since I was going to do a total rebuild. Cases were not cracked so good to go!
I found a 1988 FZR4003EN model that I used as a base.
Here she is..Lovely little thing huh?
When I took this pic I had already removed the original swingarm (I had other plans for a swingarm) and sold it off for start up cash for the project. I only wanted the frame from this bike so I parted out everything I could that I did not need.
I stripped her down to the frame and kept the following:
1) The Frame
2) The Engine Cradles (Rails)
3) The fuel tank
Thats about it
I started to get the rolling chasis squared away. I sand blast it and cleaned up a few rough areas.
I then sent it out for powder coating
Sorry a few begining build pics are no longer with us due to a computer crash. RIP
I then bought a 3TJ swing arm out of Japan. The 3TJ model of the FZR-400 was its last I beleive and it had a bunch of trick shit on it much more race like.
This swing arm was braced and wider to accept a wider wheel.
Here she is after clean up and powder coating. Honda F3 wheel in place but not fit up yet.
The original one was like in the 1st pic of this thread - straight not braced and skinny.
I then found a Honda F3 heel and began a freaking journey through hell to get it on there and actually work right.
Here goes the fit up part of this thing.
All parts ready to install.
The Honda F3 will in fact fit in this swingarm. All you have to do is find a talented machinist to give you hour upon hour of his time for free becasue if you had to pay him to figure this out you would go broke. besides you are racer so you are inherantly poor, I know I am. ha ha
I found a machine shop that was willing to sponsor me all my machine work for this project.
I did not even have to beg much.... much Actually what I did was beg him to do some one off work for me (Chinese usually have a 1000 minimum order when you want something done. A one off is a favor not a job)
In return I would pay for the job and material and put a sticker on my bike and his name on my leathers. He had no concept. Chinese have no clue about sponsorship and how it works.
June 2009 Pan Delta Series Zhuhai F1 track (30,000 fans)
But here I am at a race on a bike with his sticker on the side. Its the ZT sticker near my knee. His company name is on my thigh. I have no clue what it says. Somethign like Shanghai Tool and Die company LTD.
I can't read that shit. I can only speak it and not that well really. My Chinese wife says I speak lieka 5 year old.. same vocabulary ha ha. But Iget by Ok here.
I gave him this pic for his office wall.
Then, he understood. He showed clients and friends and anyone who would listen that he was part of this bike and did the machining for it. So it helped set him apart from all the other bazillion machine shops here.
Now he does it all for free. I give him free entry tickets to the race for him and his friends which I get for free anyway from the track manager (My friend) and life is grand. Sometimes you really need to take the first step and show a perspective sponsor how it works to their benifit.
Opps, sorry off on a how to land a sponsor tangent.
So here are a few pics of the work needed to make this thing work.
1st the width of the pivot area was exact so that was cool.
But the pivot bolt hole in the frame was of a different size. So I had a new pivort bolt and a sleeve made to take up the slack.
Old pivot opening
New pivot opening
Original 3TJ bolt and newly machined bolt. I guess drilling out the frame would have worked easier but I did not want to mess with frame integrity and thought this the safer route structurally.
It is a race bike and race stress is a concern of mne. (new bolt later machined to have a simular head-not round)
I could have used the original smaller bolt off the bike but Pete (Machinist) did not like the looks of it and made me a new one complete with machined nut.
So now the thing is mounted in place and secure. Rebuilt Fox Twin Clicker rear shock installed right up no issues.
Now the hard part the rear wheel monting set.
Here is what I did in this order
1st found exact centor of the bike. Machinist used about 30 points of refferance to measure adn check adn recheck and find exact center of the frame looking from rear to frontsplitting the biek down teh middle.
2nd Found exact center of teh Honda F3 wheel
3rd Made a spacer for the sprocket side that would set the wheel center and frame center in true alignement.
4th Installed the Honda F3 caliperusing the original honda F3 caliper mount.
5th Made do-hicky (Highly technical term) to make the F3 mount mate with the Yamaha Swingarm stay.
6th Made sure the caliper was dead center of the rear rotor (Bought a wavy rotor for the rear)
7th Made spacer to between the wheel and caliper mounting bracket adn also between teh caliper mounting bracket and the swingarm.
8th Made a spacer for the sprocket side so the wheel was now dead nutz center in the swingarm.
9th looked at where the front sprocket was, the rear sprocket mounting bolts (Sprocket would not fit in the swing arm at this point without hitting the inner side of the swing arm)
10th scratched head and tried to figure out what the hell to do next.
11th machines down the inner hub
12th Machined down the hub part of the wheel that holds the cush drive
13th double checked and machined a bit more so that the rear sprocket was now in perfect alignement with the front sprocket so no of set sprocket is needed.
A stock YZF600R front and a stock Honda F3 in the rear.
Good to go Now I can put a 160 or even a 170 tire in there instead of a 140 which was stock Yamaha FZR400 1988 model configuration. I also now have a 17" rim not a 18" rim, again original FZR400 size.
I raced on a 160 but I think Dunlop makes a 165 slick which I will use at the Shanghai F1 track and see how that works My concern is pinching a 170 on there might not give me the profile I want for cornering. Have to experiment.
Ok so lets stick with Pete and his machining efforts.
I bought a set of case savers. Suppose dto fit. but did not - of course.
I had to machine down the inside a bit to get this piece to fit on snug.
OK Rear sets.
I have no pics of the originals but think 1988 stock foot pegs and you might get the picture of what they looked like.
I used them before and at an AMA National race in Loudon, New Hampshire USA.
I had to actually cut the pegs, 30 minutes before the race, with a saws-all because tech inspection said I had ground them to a point in the corners so much they were dangerous. So I hacked them up and went racing on 3/4 of the original peg length.
I also decided I wanted adjustability.
There is really nothing good out there for a 1988 FZR-400 so I designed my own based off a few features I liked on Vortex and a few other name brands.
I came up with these. Function was primary over form so not beutiful looking but they work well.
Goofy heal guards are right on target.
In this pic you can also see the weak swing arm and thinner tire issue on the stock FZR. (This pic is of me testing them on a pretty stock FZR-400)
Pete machined them on the CNC I just gave him the specs and what I was looking for he did the CAD drawings as well.
Even though he is a sponsor I was able to get these things working quite well and made 30 sets and sold them all to other FZR owners and racer. so he got money for that and I got more money to help fund the project.
Carbon fiber parts -
I have a sponsor called OYA CARBON (www.oyacarbon.com) They make my Carbon fiber body parts for me. So far they have sponsored me 2 sets.
I gave tehm a FZR tank cover which is really jsut a cover as teh tank is a seperate cell sititng low in teh frame.
I covered teh filler hole on teh original and made a few other smal mods and sent it to them for moldign and making a few one offs for me.
I also took the rear section off a TZR-250 3XV model as I had one laying around and modded it up pretyt heavy
Original pieces mocked up... they just did not work for me.
Here are a few pics of what I did
The seat - I had to cut off the seat front tabs, change them from one side to the other and flip them over 180 degree to make the TZR seat conform to the frame of the FZR.
I also added an F1 type vent on the seat top-back. I had one of these left over from a vespa scooterhorn cover projevct I made for a USA client.
So I grafted it in the mock up for molding. Reason being that I wanted the air flow to go over my body and through the vent to get air in there to cool the electronics. I have a vent hole in the tail rear to allow for flow and not cause drag.
The tank cover I just filled in everything including the filler hole and made it smooth.
I planned to cut and lower the fuel cell so the filer hole was no longer needed. I would make the cover quick release for filling purposes
End result when I got them and stickered them up (Of Course)
Oya also provided me with a front fender for the R-6 2007S model I used for the project.
Fuell cell cut open blasted welded and then sealed with a JB weld type material. No leakes passed the test 100%
I cut this down for a few reasons.
Loose weight? No not really but actually I have less capacity now so less fuel to fill it. I geenrally only do 12 lap sprint races here.
I have a lower center of gravity I guess but I also wanted a smooth top for sliding around side to side when I race.
I added anti slosh foam which seemed to help a bit also.
I got rid of the exhaust wrap
8000 fans watching the action
