Results 1 to 5 of 5
Thread: Project Trailer!
    Member Dominic's Avatar
    Jan 2008
    Mount Hawthorn
    F650GS Dakar
    Project Trailer!
    Alright!
    Scenario: I'm moving to broome, with out a car, but i have a motorbike!
    i aquired a John papas 6X4 trailer, fairly good nick. which im going to use to tow my bike up north.
    i have also aquired 9 X 25X25X2400 tube steel and a sheet of welded mesh!
    Goal: to build a cage for the trailer! and general maintenance
    Tools:
    im borrowing a tig welder, and have very little experience, but will have someone with a little more experince around.
    angle grinder
    socket set
    drill
    Questions: does anyone have a good plan for the cage? i dont wan to weld the frame to the trailer, just bolt it.
    and i might need to leave the front with out some cage ans i think my bikes a little long
    any easy way of telling what bearings i need?
    tips on de-rusting.? i will be using rust converter-primer-rustguard
    anything else?
    Dom
    Apr 2009
    Walliston
    Pumba
    408 times
    11 Post(s)
    Don't go with plans from others, make the design reflect your needs. If you are unsure go to a trailer sales yard and have a close look at the caged trailers on display to get some ideas.
    Member Brendonv's Avatar
    Apr 2010
    Ballajura
    Suzuki DRZ250 , Suzuki TS185
    Bearings. Take the bearing out you need and take it to a bearing shop. I dont recommmend CBC, there a rip off. If ur close i go to Apollo Bearings and Transmissions in Malaga just off malaga drive. There cheap and good. If not then just google bearing shops near u and ring around. I saved about 100 bucks going to apollo.
    As for the rust converter, great stuff but also nasty. Be careful and wear gloves. Its real nasty shit. Your options are rust converter, grinder and sand paper. Get some wet n dry and work those arms. If u want to take the easy route then get a flapper disc and u will have that rust of in 2 seconds. I would do up a plan to suit your needs. Not sure if there are certain rules and regulations on trailers so you might want to do some research on that too.
    Good luck.
    Member timmay's Avatar
    Jan 2008
    Vic-Parkish
    Sell me yours?
    4 times
    Is it licensed already, or will it need to go over the pits?
    Quote Originally Posted by Desmogod View Post
    Nobody was bagging scooters, they were bagging you.
    Jan 2008
    Mount Hawthorn
    F650GS Dakar
    thanks guys! flap disc it is!
    im in ozzy park, ill call around for bearings.
    Timmay - yes it is still licenced
