Page 1 of 2 12 LastLast
Results 1 to 20 of 25
Thread: Project Yamaha XS400 Bobber
    Member Mizer's Avatar
    Feb 2006
    IN THE MOMENT
    Honda SP1 - KTM LC4 - Yamaha XS400
    Just picked up this 1981 Yamaha XS400. Its a runner but not registered, previous owner had it on club plates.
    50k on the clock, everything works as it should, this model came with the electric leg in addition to the kick start.
    First up will be a run over the pits after I get a new rear hoop and tidy up a few small issues.
    I had been looking for a project for some time and then this came up. I had initially wanted to go down the Cafe path but on further research found some great examples of bobbers and choppers and I was hooked.
    This build is my first and I imagine it will take a long time, so let the fun begin.
    This is the style I am chasing and my inspiration for the project.
    "Last time I whined like a bitch cos I'd given blood that morning and was on my rags" Shai'tan Nov 2010
    Member RiffRaff's Avatar
    Aug 2007
    ZXR's
    Subscribed. Good Luck
    Member brethren22's Avatar
    Mar 2009
    Sydney, Australia
    1977 Yamaha RD400, 1981 Honda C90
    3 times
    yeah good base to start with. short shocks and a chop job on that back end should get you moving in the right direction. that SR is a good source of inspiration too, good luck with it!
    Member RIPLEY's Avatar
    Jun 2010
    byford hills
    xj 750 bobber xj750r sand dragger chopper mower
    31 times
    Sweet love bobbers good luck with it, i must say tho it looks particularly lovely and original it almost seems a shame to chop it when ther are so many dogs out and about.
    Japbobbers.com is a great site as is xjbikes.com they have a other yammys section.
    "There is more in heaven and earth that can be explained by your philosophy Horatio."
    True, but if science had the funds religion has enjoyed for eons we might have better explanations by now, or at least hover shoes.
    Member Triple's Avatar
    Sep 2006
    Yamaha Triples '78 XS750E, '79 XS850SF, '80 XS850G, '06 ZX12R
    7 times
    Hey mate, I've got a barely used Haynes workshop manual here if you need one...
    Feb 2006
    IN THE MOMENT
    Quote Originally Posted by RIPLEY View Post
    Yeh it is a great example, tho its my dream to Bob......I hunted for 2 years to find a good example as I wanted to start from a good base.
    Quote Originally Posted by Triple View Post
    Would be awesome Triple.............................PM sent.
    I plan on starting a few bits this weekend.
    Member DJ Vieyra's Avatar
    May 2009
    Aveley (Ellenbrook)
    Yamaha XS750 Triple Cafe Racer, Yamaha XS250, Yamaha FZ6N
    Good luck with the build!!
    I have a XS250 and XS750 in case you need anything just holler!!!!
    Apples & Pears!!!!
    From Da Geeza!!!
    Feb 2006
    IN THE MOMENT
    Quote Originally Posted by DJ Vieyra View Post
    Woo Hoo, cheers for the heads up.
    Member fatoxious's Avatar
    Jun 2010
    16 times
    hell yeah, nice one man. good luck!
    Home is where the Art is.
    Feb 2006
    IN THE MOMENT
    Got some work done on the bike over the weekend in readiness for the pits inspection Tues
    Oil Change
    New rear tyre fitted by hand, old enduro skills come into play.
    Sorted the Tacho, if this passes the pits I will explain
    Secured the seat, dodgy of course.
    Degreased the beast and gave her a good clean.
    This is where she is at now, all going well it passes inspection and the real build starts.
    New Member
    Oct 2009
    Lookin' schmick bro
    Aug 2007
    ZXR's
    Quote Originally Posted by Mizer View Post
    With those skills, I reckon you should get a job in the tyre industry cob!
    Looks good
    Feb 2006
    IN THE MOMENT
    Well the bike failed inspection today for steering head bearings and an incorrectly adjusted chain and rear drum brake (tho they appear fine to me)
    No biggie it could have been pinged for a whole lot more I suppose.
    Now to order the bearings, then adjust up the chain and brake for another try
    Member Vosy's Avatar
    Jan 2009
    Mandurah
    TBA
    10 times
    Knit pickers
    Its not the size of the dog in the fight, but the size of the fight in the dog.
    Feb 2006
    IN THE MOMENT
    Pulled the front end apart and the bearings went every where, found them all but one. Was a new one for me as I have only ever replaced caged bearings in dirt bikes.
    soooooooooooooooooooooooo
    How close should the bearings be when sitting in the race? to me there is a lot of play like I could fit 1/2 a bearing in (if that makes sense)
    The bearings and races appear fine to me but I am going to replace them anyway since its apart, manual says 1/4 balls.
    Pics of the mess to come.
    Still cant figure out their issue with the chain, any tighter and there is no play.
    Member Tbird tracker's Avatar
    Apr 2009
    Sydney
    1958 Triumph 650 Tbird
    If your going to replace them anyway, you should consider tapered roller bearings. I'm sure there would be a kit available for the XS250, they will be a better setup and much easier to install as yo know from your dirtbikes.
    Nice original bike by the way, I'll be following with interest.
    Oh, to answer the question , about half a ball bearing of free space with all the balls fitted is about right. This is to avoid any chance of the balls binding against each other as the grease wears.
    Feb 2006
    IN THE MOMENT
    Quote Originally Posted by Tbird tracker View Post
    Cheers,
    Think I will put the ball bearings back in just for the pit inspection and replace with roller when I rebulid after the strip down for paint.
    Feb 2006
    IN THE MOMENT
    OK so I went for the second inspection, guy passed it straight away.
    Off to get the rego, am now told at this point I need proof of purchase from previous owner. Faaaaaaaaark me! emails, faxes and phone calls latter all sorted.
    So she now has a spanky new plate and I can legally take her for a spin.
    Prior to running it over I sorted a few problems and some in true dodgy style.
    Cable tied the seat down as the retaining latch is worn beyond repair.
    Purchased some new loose ball bearings for the steering stem, cleaned up the existing races then greased them up. Dropped in the new bearings and put the front end back together. Jumped on eBay and brought some roller type bearings for the actual rebuild.
    The tacho cable on the bike was screwed and to be honest the gauge
    looked like crap, I had no intention of running a tacho so the solution was easy. I pulled it apart and binned the guts, then simply painted the back of the glass black and put it back on the bike.................what tacho? it never had one
    I may be tempted to ride her for the next month or two before the strip down ........
    So that’s all sorted, now for the next phase.......
    Apr 2009
    Sydney
    Good work getting her rego'd, now let the fun begin!!
    New Member
    Oct 2009
    Any updates?
