Results 1 to 8 of 8
Thread: Aprilia RS 125 34mm carb jetting HELP!
    New Member
    Mar 2010
    Aprilia rs 125
    Hey guys i own 2004 aprilia rs 125
    Just wondering what pilot, main jet size you're using for 34 mm carb?
    Im using 165 main 36 pilot and needle is in its leanest.
    Tried 40 (what it came with), 41, 41 pilot jet.
    Then i got recommended 36 pilot by PJME
    Still jerky about 1/4 throttle at 5000-6000 rpm.
    Should i go even lower?
    Cheers..
    Member Loud's Avatar
    Dec 2009
    South. Just.
    41 times
    5,000-6,000 is where the emmissions dip in the factory CDI occurs, causing hesitation due to ignition retarding. You won't be able to tune it out without changing to an aftermarket CDI such as the Zeeltronic.
    Comparing jet sizes between bikes will only be useful if you know it has similar mods. Whatcha got?
    New Member
    Mar 2010
    Aprilia rs 125
    I got
    Gianelli's
    34 mm carb
    Vforce reed block
    K&N air filter
    I actually have the singe curve CDI at the moment. I read about this before but before I had it all change it rode smoothly even between 5000-6000 rpm.
    Which jetting you're using mate?
    Dec 2009
    South. Just.
    41 times
    I had a similar setup, but with a Pipercross cone filter (no airbox) and Arrow chamber. It used the stock setup from PJME for the needle and pilot, but with a 165 main. But it was way too rich, and I didn't tune it because it was only whilst I was waiting on the Polini kit.
    In my very limited jet tuning knowledge, the RPM would be indicative of the needle needing to be adjusted. Best to look to wiser heads for their opinions though!
    Member shaynoinsano's Avatar
    Feb 2010
    Newcastle / Branxton.
    APRILIA rs 250
    "calling eeknows!!!"
    ???anyone out there got a rs250 with 5mm longer rods???
    Jan 2010
    subiaco
    twostroke
    3 times
    try a 42 pilot and 165 main K55 needle middle clip.Take some good advice and put the airbox with snorkel back on.
    Dec 2009
    South. Just.
    41 times
    Quote Originally Posted by EEKNOWS View Post
    But the sound!!
    Jan 2010
    subiaco
    twostroke
    3 times
    I'll take HP over noise anyday
