Results 1 to 3 of 3
Thread: Battery Eliminator ???
    Member Watsoff's Avatar
    Apr 2010
    RD350LC
    I am in the middle of a Yamasuki project bike, 350LC with RGV front and back.
    I want to leave the sides open and so need to get rid of the battery or locate it elsewhere, probably under the single seat unit which has limited space.
    I have heard that you can fit a small battery, just for running the lights, or fit a battery eliminator which will still work all the lights when the engine is running.
    Questions!
    What capacity, volts and amps, does the new smaller battery need to have?
    Where do I get one of these eliminators?
    Will you still get through rego with the eliminator fitted?
    Thanx in advance for any help
    Member Chewie's Avatar
    Sep 2007
    All over the shop
    Yamaha R1
    64 times
    7 Post(s)
    May 2009
    adelaide
    rz 350
    i know borut from zeeltronics does a battery emliminator for the 350.. ZEELTRONIC - HOME
    or you can check these guys out, i will probalby get one from them for my build.. http://www.antigravitybatteries.com/
