Perth Street Bikes
Go Back   Perth Street Bikes > MOTORCYCLE TOPICS > Two Strokers
Two Strokers For those that get it done in two strokes not four.
Reply
LinkBack Thread Tools
Old 10-08-2008, 08:53 AM   #1 (permalink)
Aprilia RS125
russkigreg's Avatar
changing 2 stroke oils
Hey all, chasing a bit of advice-
I run an Aprilia RS125, which currently uses Motorex Speed Mix 2T oil, fully synthetic. Got advised to change to Motorex Cross Power 2T, which is a lower smoke synthetic blend. As I'm not racing it should keep my engine cleaner?
SO: Is this sound advice? And if so, am I likely to cause any problems by changing the oil type in the engine? (Ie should I drain the tank first, mix half half etc...?)
Any thoughts on the matter would be appreciated.
russkigreg is offline   Reply With Quote
Old 10-08-2008, 09:10 AM   #2 (permalink)
druu's Avatar
The easiest method would be to run your tank low and top it up with the new stuff. If you're using the bike daily this shouldn't have any effect on mixing the two oils. I did this with the RGV (changed from Shell to Castrol) with no problems.
Just decide if you really need to first.
druu is online now   Reply With Quote
Old 10-08-2008, 09:17 AM   #3 (permalink)
CBR600RR7, 1.5x VJ22 RGV250
thro's Avatar
^^ have heard that some combinations of oil can turn to jelly and clog everything up.
Personally, I'd drain the oil and fuel tank, run say, 5 bucks worth of premix fuel through the bike (no oil in the oil injection) and then re-fill with the oil of your choice.
Paging RGVLee...
__________________
310rwhp 180sx for sale. most bolt ons (turbo, injectors, ecu, brakes, suspension, etc), $11k. pm for details
New to riding? Or group riding?
thro is online now   Reply With Quote
Old 10-08-2008, 09:27 AM   #4 (permalink)
personally i woudnt waste my time changing, most synths would be much of a muchness
ritza350 is offline   Reply With Quote
Old 10-08-2008, 09:32 AM   #5 (permalink)
druu's Avatar
thro: yeah some can turn to jelly although from what I've read that's only after prolonged periods. Running the tank low and topping up is completely safe.
Old 10-08-2008, 10:34 AM   #6 (permalink)
Cagiva Mito
bertie's Avatar
the jelly theing happens when you mix castor with some synths.
if ur sticking with the same brand just changing blend then you should be right topping the oil res up with new stuff at any time.
__________________
bertie is offline   Reply With Quote
Old 11-08-2008, 07:30 AM   #7 (permalink)
rgvlee's Avatar
what bertie said. fully synths it is generally accepted they are safe to mix.
rgvlee is offline   Reply With Quote
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
» Sponsors
» Current Poll
What Learner system would you want in WA?
250cc Only - 14.75%
9 Votes
Lam approved - 72.13%
44 Votes
I don't care, whichever. - 13.11%
8 Votes
Total Votes: 61
Advertise on PSB
