Results 1 to 4 of 4
Thread: Chasing some RZ reed stops or Banchee reed blocks complete with stops.
    Sep 2011
    perth
    rz350
    9 times
    Hey guys and girls has anyone in Perth got a set of RZ/Banchee reed stops laying around they no longer need, I can come and pick em up this weekend, and will leave a cash donation, I know this is not the place to post wanted and advance apologise, but, this is 2 stroke specific stuff so Ill take the gamble of getting a kick up the arse, as a fallback, are any RZ owners here running the Banchee reed blocks? whats your opinion (on the banchee reed blocks that is)
    I got some new boysens to go in, and nothing to stop em.
    Please PM me if you can help
    Member aaronmvrider's Avatar
    Feb 2010
    gosford
    rz 350, rz500, mv f4 1000
    are they the same as rz reed stoppers... i got 2 new sets from TSS.... you want a set ???? from memory they are around 10 mm from reed face...
    1984 rz 350 stroker
    1984 rz 500 original
    2004 mv agusta f4 1000
    1994 mitsubishi magna wagon
    Sep 2011
    perth
    rz350
    9 times
    Quote Originally Posted by aaronmvrider View Post
    Prety similar I think, might have to open up one of the holes to fit but dont quote me. I read some comparisons on the crazy sight someone was kind enought to post, the banchee reed blocks (internal measurements) are almost identical (I think 1 or 2 mill wider), and the blocks will fit the RZ intakes with a little bit of a file on the standard intake floor.
    At any rate, I just picked up a set at a wreckers in Perth (stops only), but thanks anyway for the offer Aaron, I took a gamble, 10 dollaro's. The holes match the Boysen holes, just got to do a search to check the opening measurements, and I think from memory I can open up the top reedstop a fraction beyond spec. Ill post the specs later if anyone is interested.
    Sep 2011
    perth
    rz350
    9 times
    Quote Originally Posted by seahorse View Post
    Standard RZ Reed stop Openings 10.3 +- 0.2 mm
    Banchee reed blocks are about 3 mil wider and .5 deeper than RZ, dont quote me, got it off another site ( Bolt hole patern mounting to barrel same. RGV reed blocks are way wider "massive", no wonder they go so bloody fast.
