Results 1 to 3 of 3
Thread: electrical wows wont keep charge
    May 2009
    newcastle
    mito400
    hey just got my self alil tzr only 25000km on the clock i had to clean it up and tidy but all seems good how ever, i conected a batt charger direct to the bike all lights and electrical stuff worked..i bought a new batt..all was good and i went and registered the bike..first big ride today about 30km into it all it all went dead.no lights or indicators..no pv cycle when i turned the key then i kept riding and i stoped and then had power..a slight amount..pv cyle worked, loom looks good no tampering fuses also good..does this sound like a regulator or rectifier prob..any light on the matter would be good,,,,thanks
    Member darkfibre's Avatar
    Apr 2009
    Walliston
    Pumba
    87 times
    Sounds like its not charging for sure.
    Bendito did a write up a while ago, and its a good place to start to determine if its regulator or stator etc.
    Have a look here Problems with Charging System? - Fault Finding Guide
    Unfortunately, Darkfibre
    based on responses to our questionnaire, we occasionally find situations where our matching system cannot identify high quality compatible matches, and this has happened in your case. Please understand that it is a result of our matching process and in no way reflects on you as a person or your ability to be in a happy relationship
    [eHarmony]
    May 2009
    newcastle
    mito400
    ah i think i just solved it...i think on the tzr as on the late rzs the regulator rectifier needs to be grounded directly to the frame i remember moving the reg when i cleaned up the electrics and modded the new seat..i think this is the prob
