Results 1 to 7 of 7
Thread: Engine fuel starvation and stalling
    Member spikes's Avatar
    Jun 2009
    Terrigal
    RGV250, CBR954RR
    Okay so the motor is out of a Tanaka whipper snipper and not a motorbike but all two stroke motors are based on the same principal.
    Basically what is happening is it will run for a little bit and then start loosing power as if it was being starved of fuel and then it would stall. What could be possible causes?
    Member agrid's Avatar
    Apr 2008
    271 times
    13 Post(s)
    Pull the carby apart and give it a clean, if you are careful you wont need gaskets, crap builds up being the diaphragm that pumps the fuel around so it can run upside down.
    PSB Corporate Sponsor Munkers's Avatar
    Jan 2010
    Perth Hills
    GSXR1300 Hayabusa, Suzuki B King, 1962 Triumph 500 cc Speed Twin.
    152 times
    18 Post(s)
    Check the fuel line from the tank to the carby, the fuel lines are made from a material called Tygon and will harden and crack over time, a small air leak in the line and you will get exactly what you have described. Remedy, relace the fuel lines, and if you have any trouble getting the Tygon tube PM me as we have heaps here.
    If at first you don't succeed, dont bother taking up sky diving.
    This unit is portable when carried.
    it wasn't a normal cookie, i figured that out 45 minutes into my exam.
    Member BusaSteve's Avatar
    Dec 2010
    SOR (just)
    Hayabusa
    7 times
    I have had a similar problem and it turned out to be carbon build up on the anti spark screen. Two strokes are reknowned for building carbon up in the exhaust port too. Another problem may be the low or high speed mixture. For a ballpark figure set them both to one and a half turns out. The motor should idle smoothly and accellerate cleanly with no hesitation up to full speed.
    doesn't play well with others
    Typical isn't it? You're just having a shit and the phone rings
    Jun 2009
    Terrigal
    RGV250, CBR954RR
    Thanks guys I'll give that a try and see how it goes.
    Member HK31A's Avatar
    Jan 2010
    Perth WA
    how did you go mate
    get it sorted?
    Jun 2009
    Terrigal
    RGV250, CBR954RR
    haha still haven't gotten around to it mate, been so busy with work lately I haven't been in the garage lately. Going get stuck into dropping the motor out of the R1 and stripping it down tonight so while I have my hands dirty I'll take a good look at it
