The jet size problem
some selected jetting wisdom:
The jet number is linear dependent from the fuel flow which means a #120 main jet has 20% more fuel flow compared to a #100 jet. Do not mistake fuel flow with jet bore diameter! This dependency is not linear!some of my jets had a serious mismatch between label and fuel flow of upto #30 numbersFor this reason I’d advise anyone who is going to change jetting to make his own jet measurements. The values will be different but the intention is to compare "unknown" with "known" jets and to judge if the jet label is in a valuable range.
I used a rinsing bottle for battery acid (diameter about 70 mm, about 180 mm height) with an 80 mm hose with 5 mm inner diameter (to screw in the jets). Pour in an exact amount of water using a small kitchen measuring jug or letter scales and measure the time in which the whole amount has flowed out.
im going to create the same table for all my mikuni jets, my tunes are going to be sooo perfect![]()
