15-06-2008, 05:46 PM
#1 (permalink)
RGV250
NEED DE-RESTRICTED SAPC BOX.. help
Hey I just removed my carbs from '94 RGV250 motor and they seem to be the 34mm Mikunis, but i checked the sapc box and its a restricted model as far as i can learn... (22D00 - restricted Jap model according to rgv250.co.uk) The 22D00 box comes standard with 32mm carbs but mine are 34mm... Whats the deal? Either way, i want, no - NEED a de-restricted sapc box so someone please give me some love, and a price!
__________________
Of all the things I've lost, I miss my mind the most - Jimi Hendrix
16-06-2008, 05:55 PM
#2 (permalink)
CBR600RR7, 1.5x VJ22 RGV250
^^ 34mm carbs are standard on VJ22, but the 22D00 ECU isn't as far as I can tell from the service manual.
best bet might be to try a wrecker or e-bay, i doubt anyone who actually has a derestricted ECU is going to part with it unless they're wrecking a bike?
__________________
310rwhp 180sx for sale. most bolt ons (turbo, injectors, ecu, brakes, suspension, etc), $11k. pm for details
New to riding? Or group riding?
17-06-2008, 10:13 AM
#3 (permalink)
RGV250
yeah i was worried that might be the case - well ill give the wreckers a buzz i guess, cheers thro..
__________________
17-06-2008, 04:46 PM
#4 (permalink)
Rs250 '03
search for either ignigitech or zeeltronics programmable ignitions onlie or on The Tuning Works
or www.rgv250.co.uk
17-06-2008, 05:24 PM
#5 (permalink)
Rs250 '03
even better, email and ask see what this guy can do for you - info@zeeltronic - Borut Zemljic
17-06-2008, 05:34 PM
#6 (permalink)
RGV250
thanks Trav, if nothing comes up locally i'll give it a try... Cheers
__________________
17-06-2008, 08:16 PM
#7 (permalink)
2 strokes, please!
Zeeltronics seems to have a good reputation in 2 stroke circles (RG500, RZ500) according to the forums and the feedback on them.
18-06-2008, 07:38 AM
#8 (permalink)
Yeah they do, but you will need to wire it up and configure it. You're still finding your feet at the moment so I'd be looking for a 22D30 or an aprilia 23D70 I think it is if you can pick one up cheaply. The aprilia brain box will smooth out the 8.5k lag. Speak to deet at rgvspares.
18-06-2008, 10:37 AM
#9 (permalink)
Rs250 '03
the zeeltronics comes with three curves and room for one to play with for yourself
18-06-2008, 10:45 AM
#10 (permalink)
I can appreciate that, I'm buying the ign and pv controller for my black rgv.
However, and I mean no disrespect to the original poster, but he's still learning the ropes so to speak with his bike so I stand by what I said - the SAPCs are around and are plug and play whereas the zeeltronics are not. They do need to be wired up and they aren't something I would recommend to someone who is just starting to do their own maintenance.
18-06-2008, 10:58 AM
#11 (permalink)
Rs250 '03
ahh, i see. only one way to learn though!
18-06-2008, 11:26 AM
#12 (permalink)
2001 Ducati 748R
Meh, I'd rather plug in an SAPC knowing it works, and spend my time figuring out how to clean and adjust PV's, than spend my time wanting to burn the bike because I know SFA about 2 strokes or ignition curves.
But that's just me.
__________________
18-06-2008, 08:52 PM
#13 (permalink)
^^ what desmo (and lee) said.
I would wager you can probably pick up a genuine SAPC unit cheaper than any aftermarket solution as well, so long as you actually find one.
My experience with aftermarket management on cages also tells me that even if you get it tuned by someone who knows their shit, unless you're willing to pay them for a LOT of time in tuning, you'll never get anywhere near the level of refinement of the factory gear with aftermarket management. Sure you might put out more power or whatever, but the factory gear "just works" in all weather conditions, etc.
Good luck with it
__________________
19-06-2008, 07:29 AM
#14 (permalink)
19-06-2008, 07:56 AM
#15 (permalink)
2001 Ducati 748R
^^^ $15?!
I think it might go for slightly higher than that.
__________________
21-06-2008, 02:19 PM
#16 (permalink)
RGV250
Thanks for the input guys, i appreciate it. With a little luck i may have a 22D30 sorted!  Ill keep you posted, cheers!
__________________
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
» Sponsors |
