NS400R parts anyone interested ?
got the atac chambers?? do you think I could fit them to another bike??
Not so sure about that one dplb ? Fredie ,had a couple of pm s from yer about the fairing set/tank but HK31A got in before yer.Thourght I sent you a PM ? Appoliges.
Im guessing they are either between the cylinders and the exhaust or in the header pipe if yiu have the std pipes. I think the 400 only had them on the two front barrels?
I have the ATAC system dplb if interested ?
can you put some pics up? I havent actually seen them in the flesh
can you measure their size I need to know cause i want to put them on an rz thanks max do they fit inbetwwen the cyl and exhaust?
Not sure that would work mate as I believe it has an ECU that controls them ?
The two ATAC systems lie under the front cylinders.They fine tune the exhaust system.
mate . i see swings arms . motor parts . exc. what u doing ??
I don t remember putting any swings or arms up for grabs ?
those parts are in your pics
All up for the taking Fredie.The pro arm is a conversion we made for the NS400R,bolts straight on.
ok m. pm sent on swing arm
Fredie,apparently you can t recieve anymore PMs until you clear yer inbox ? Are you still interested in the pro arm ? 8,000 thai baht for the arm/rotor,calliper and all nescersary bearings, approx 2,200 postage to O z ?
pm for swing arms please
fredie,I can t pm you with details ,your inbox is ful ?
- You may not post replies
- You may not edit your posts
Forum Rules
Content Relevant URLs by
vBSEO 3.6.0
