Results 1 to 6 of 6
Thread: NSR150 engine number location
    Member smitto81's Avatar
    Dec 2007
    perth
    3 times
    Hi all, can anyone help me with the location of the engine# for the bike mentioned?
    so far ive looked under the gearlever, under the engine, at the back of the engine below the carb, and everywhere else i can think of without removing the tank and fairings. There is a tab below the clutch cover on the crankcase but it is blank.
    i rang honda and they suggested the places above and if i have no luck to call back and the can look on the parts fiche.
    Maybe someone here can help?
    thanks, Nathan
    Lost and on reserve
    Apr 2010
    townsville
    rd350lc
    Nathan,
    For what its worth I can tell you the NSR400 is on top of the cases towards the back of the engine on the flat - look for a flat plate where a number should be, it may have been removed for some reason and the plate will be the tell-tale.
    cheers
    BW
    Member Sharky's Avatar
    Oct 2011
    North - way north
    Aprilia RS125 & Ducati 1198s
    19 times
    Dec 2007
    perth
    3 times
    thanks sharky, i couldnt find anything like that when i looked!
    problem now is that its been removed
    Lost and on reserve
    Apr 2010
    townsville
    rd350lc
    As I thought - Not a problem, you just have to get a new number from licensing - Honda did not match ennige / frame numbers from my research i did on the NSR.
    When you register it they give you a number and you get it stamped.... or you go to a wreckers and get a busted engine - stamp that engine number on the block and destroy whats left of that engine so it cant be reborn.
    BW
    Dec 2007
    perth
    3 times
    thanks oiler, i was a bit stressed about it but a call to the licensing centre confirmed they only need a vin number.
    was thinking of getting another case, just didnt think of getting the numbers stamped
    Lost and on reserve
