Results 1 to 13 of 13
Thread: powervalve assembly problem
    Member BrendonM's Avatar
    Mar 2007
    secret harbour
    07 cbr600rr
    ok so got everything in, then go to put shaft in and the last spacer wont go on straight the bolt underneath is holding it there on an angle.
    any special way to do this?
    p.s yes i have used the correct bolts.
    Member chee's Avatar
    Dec 2004
    Fremantle
    Slingshot, RGV250, Monark
    its pretty straight forward.
    are you talking about the grub screw? and the lifter arm thing?
    Sep 2005
    Marangaroo
    8 times
    i'm confused which bit you're talking about?
    Buy my bad ass 421cc TZR - $5500 ONO - http://www.perthstreetbikes.com/foru...engine-134321/
    Member rgvlee's Avatar
    Gamma Manor
    7 times
    as above, i have no idea what you're referring to.
    Mar 2007
    secret harbour
    07 cbr600rr
    i figured out what i was refering to before, i now have a new problem which that diagram doesnt explain
    -i dont know what position/where to rotate the pully?
    -i dont know what postion that the spring mechanism behind to pully should be or what it does?
    -and the top bolt behind the pully im not sure what it does or whats meant to be there?
    this all realates to the bottom/right hand cylinder.
    thanks
    Sep 2005
    Marangaroo
    8 times
    okaaay, your talking about number 30 i'm assuming? that screw holds a washer over number 29. so that number 29 can't pop out and then swivel, because that would stop the pulley (number 34) from being held in to the right spot with the spring (number 32). See?
    Simple.
    Mar 2007
    secret harbour
    07 cbr600rr
    ok so that answers my last question, but im still confused about the spring and where i should located the pully "stopper thing" on the back of the pully?
    thanks again
    Sep 2005
    Marangaroo
    8 times
    The pulley and number 29 both stick in between the spring ends, on the bottom cylinder, they point towards the rear of the bike and the top cylinder they point down.
    Mar 2007
    secret harbour
    07 cbr600rr
    so ive got to get the pully "stopper thing" inbetween the springs aswell as number 29?
    Sep 2005
    Marangaroo
    8 times
    yes
    Mar 2007
    secret harbour
    07 cbr600rr
    ive got it now cheers for all the help everyone.
    Dec 2004
    Fremantle
    i had issues with that. just played around with it for 10 minutes till i figured out how it should have worked.
    Member druu's Avatar
    Mar 2007
    South Central
    08 SM510R
    With the spring attached to the shaft already, all you really need to do is line up the hole on the shaft so the grub screw can screw in, simple.
