Perth Street Bikes
Go Back   Perth Street Bikes > MOTORCYCLE TOPICS > Two Strokers
Two Strokers For those that get it done in two strokes not four.
Reply
LinkBack Thread Tools
Old 03-07-2008, 09:02 AM   #1 (permalink)
RZ250-R
g0zer's Avatar
RGV swingarm and rear shock arrangement?
Looking for a little favour, if anyone has a spare few minutes, an RGV250 and a digital camera i was hoping they could take a photo of arrangement of their rear shock and swingarm.
In particular i am interested in:
1. The alignment of the bottom rear shock knuckle
2. The clearance between the rear shock and swingarm
cheers,
g
__________________
g0zer is offline   Reply With Quote
Old 03-07-2008, 01:33 PM   #2 (permalink)
CBR600RR7, 1.5x VJ22 RGV250
thro's Avatar
Will try and get some pics tonight (camera not good in the dark)
I can also take photo(s) of a bare frame, and an assembled bike...
__________________
310rwhp 180sx for sale. most bolt ons (turbo, injectors, ecu, brakes, suspension, etc), $11k. pm for details
New to riding? Or group riding?
thro is online now   Reply With Quote
Old 03-07-2008, 01:51 PM   #3 (permalink)
RZ250-R
g0zer's Avatar
thanks mate
ritza has determined that the knuckle needs to be fairly flat when the swingarm is at its maximum extension ie: unloaded. Note that as the knuckle rotates when the rear shock is compressed, it will also move in the horizontal as per the arc drawn by the radius of the dogbones.
to achieve this he has raised the mount where the top of the shock bolts into the frame. i am trying to see if there is room for me to bodgy it by only shifting the bottom mounting location and lengthening the dogbones (the bits that connect the swingarm to the middle pivot point on the knuckle).
The geometry is actually a bit difficult for me to visualise, i think i have my head wrapped around it now after sleeping on it. Some photos of how Suzuki actually fit this arrangement would be very helpful
if i can see a photo of the unloaded geometry, i can load it into CAD and extract the angles and compare to mine. That plus the clearance between the shock and the swingarm will let me check any calcs i make (or let me just do it, without having to test out my fading trig).
__________________
Old 03-07-2008, 01:55 PM   #4 (permalink)
thro's Avatar
^^ where abouts are you?
If you like, i'll bring the RGV to scarbs tomorrow night and you can check it out in person if you're there?
edit:
Also, i believe there's an RGV service manual downloadable off the net somewhere (has frame/swingarm/etc diagrams). I may even be able to help you out in that regard (not sure if i still have it or not).
__________________
Old 03-07-2008, 01:57 PM   #5 (permalink)
RZ250-R
g0zer's Avatar
cool, that will work
edit: hang about.. fri forecast is showers and thunderstorms!
__________________
Old 05-07-2008, 12:21 AM   #6 (permalink)
thro's Avatar
^^ soft i was there. had food anyway, lol...
__________________
Old 05-07-2008, 07:10 AM   #7 (permalink)
RZ250-R
g0zer's Avatar
not only soft, but warm and dry too
__________________
Old 05-07-2008, 02:05 PM   #8 (permalink)
thro's Avatar
^^ haha.... i didn't get that wet Didn't even bother to take my placcy pants
__________________
Old 21-07-2008, 09:11 AM   #9 (permalink)
rgvlee's Avatar
does this help
rgvlee is online now   Reply With Quote
Old 21-07-2008, 09:14 AM   #10 (permalink)
2001 Ducati 748R
Desmogod's Avatar
So this was the job you where going to do on your week off, right?
__________________
Desmogod is offline   Reply With Quote
Old 21-07-2008, 10:17 AM   #11 (permalink)
RZ250-R
g0zer's Avatar
Quote:
heh yep. its still going *sigh* but i am really only waiting for my offset sprocket to arrive and for the dude at Alyz engineering to come back from holidays now
thanks Lee, that first photo that shows the alignment and the clearance is exactly what i was looking for
Mike had already explained it to me.. because the clearance is quite tight the knuckle needs to be aligned parallel to horizontal- so it cannot swivel the shock backwards and hit the swingarm. However there is a clearance of a few mm, so i think it is possible to rotate that knuckle clockwise a little without smacking the shock on the swingarm.
edit: actually its not parallel to horizontal but rather parallel to the plane the shock is compressing in. thats exactly what i wanted to know
Old 21-07-2008, 12:32 PM   #12 (permalink)
what the f**k did you just say.....
ritza350 is offline   Reply With Quote
Old 21-07-2008, 12:36 PM   #13 (permalink)
RZ250-R
g0zer's Avatar
Quote:
wasnt the reason you raised the top mounting position of the rear shock, to correct the alignment of the bottom knuckle?
Old 21-07-2008, 12:57 PM   #14 (permalink)
83' RZ250
nath's Avatar
Hahhahah..
__________________
nath - NOV 27 1:26 - Just post.. P.S. Nath said you can all get fucked for me
nath is offline   Reply With Quote
Old 21-07-2008, 01:11 PM   #15 (permalink)
RZ250-R
g0zer's Avatar
Quote:
Originally Posted by nath View Post
Hahhahah..
he is just bad tempered cos he has to sell his bike
Old 21-07-2008, 07:49 PM   #16 (permalink)
Quote:
no the reason i altered the shock mount was to fit the rgv shock in as its 35mm or so longer than the rz and 10 years newer in techanolalgy . and i think the rz one is too wide to fit the swinger....mike
Old 21-07-2008, 07:58 PM   #17 (permalink)
RZ250-R
g0zer's Avatar
did you retain the original RGV dogbone links Mike?
Old 22-07-2008, 07:27 AM   #18 (permalink)
yes , i wanted all factory parts ....and if i needed to change the ride height i would make new ones, rather than change the knuckle geometry
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
» Sponsors
» Current Poll
Well ?
Yes - 45.95%
17 Votes
No - 29.73%
11 Votes
NO.. You're a freak. - 24.32%
9 Votes
Total Votes: 37
Advertise on PSB
