Perth Street Bikes
Go Back   Perth Street Bikes > MOTORCYCLE TOPICS > Two Strokers
Two Strokers For those that get it done in two strokes not four.
Reply
LinkBack Thread Tools
Old 29-09-2008, 03:46 PM   #1 (permalink)
Aprilia RS125
RS125 Help
Went for a ride today got caught in holiday traffic and after this my bike started spluttering and wouldn't rev properly and I had to crawl home. First thing I thought was spark plug, which yes was oily ,so I cleaned it put it back bike started first time. I went for another ride hit the back roads opened it up thinking the crawling pace that morning was the cause but after 5 to 10 minutes it had over oiled again. I was just wondering what you guys thoughts are before I ring the shop. I am going to replace spark plug tomorow but I don't think thats the problem.
CHEERS
singo is offline   Reply With Quote
Old 01-10-2008, 08:34 PM   #2 (permalink)
Aprilia rs 125
Andy_Robbo's Avatar
hey man, i have just recently bought a rs125 and the same thing has happened to me also. i had rung rick gill where i bought the bike from and he told me that is was the same reason and i just gotta ride the bike harder. He also mentioned to put some spitfire petrol cleaner into your tank every couple of fills, smaller amounts of course.
Since i have done this the bike has run awesomely. 750k's on the clock now and riding beautifully.
hope this helps.
__________________
Ride Hard, or die trying.
Andy_Robbo is offline   Reply With Quote
Old 02-10-2008, 06:04 AM   #3 (permalink)
2008 CBR600RR
ozzypatrol's Avatar
Talking
could be something to do with idling along, from what i have been told you can't just sit in traffic and let it idle. You have to blip the throttle every couple of seconds otherwise oil pours into something somewhere and makes it go like shit. even cruzing slowly (car park) i got told to slip the clutch now and then and give it a rev.
ozzypatrol is offline   Reply With Quote
Old 02-10-2008, 06:11 AM   #4 (permalink)
if the traffic is moving slow, cog it back a gear or two and ride slowly revving high, make the motor do what its sposed to ...rev
ritza350 is offline   Reply With Quote
Old 03-10-2008, 02:50 PM   #5 (permalink)
Aprilia RS125
yeah thought as much but even after cleaning plug and taking it for a good wrap it overoiled again. Its still under warranty so cant hurt to get them to look at it
Old 03-10-2008, 05:14 PM   #6 (permalink)
Aprilia rs 125
Andy_Robbo's Avatar
how many k's have you done on it so far? cause my first 250k's were hell too...i thought why the hell did i get one lol but after it got worn in more i gradually fell in love again.
__________________
Old 03-10-2008, 05:28 PM   #7 (permalink)
98 R1 - Blue Goodness
Mattis's Avatar
Could be the oil pump is adjusted too rich perhaps.
Yes, two strokes do need to be ridden reasonably hard to give them a good "clean out" but if the oil is mixing too rich then it will foul plugs easily enough.
It could be that the pump is adjusted rich when the bike is sold new and then leaned out a bit when it comes in for it's first service. This could be done to ensure it doesn't seize during those first crucial few thousand kms.
__________________
Mattis is offline   Reply With Quote
Old 03-10-2008, 06:30 PM   #8 (permalink)
Old 03-10-2008, 09:30 PM   #9 (permalink)
Rikku the Rizla RGV!
Stratos's Avatar
Ditto. My PV jammed because the pump was running too rich. And try keep them up around 7000rpm when crusing. It may sound high, but she will run cleaner and be ready to go quicker if you need be.
__________________
I never claimed to be your saviour,
I said I had a dirty mouth,
Stop analysing my behaviour,
If you're too dumb to work it out!
Stratos is offline   Reply With Quote
Old 03-10-2008, 09:51 PM   #10 (permalink)
2001 Ducati 748R
Desmogod's Avatar
Quote:
Originally Posted by Andy_Robbo View Post
hHe also mentioned to put some spitfire petrol cleaner into your tank every couple of fills, smaller amounts of course.
Honestly, I wouldn't bother with this bit of advice, these bikes are built to be ridden hard, they aren't commuters. They need constant maintenance and cleaning like all 2 strokes, these things are what are needed, not some off the shelf remedy.
Thinking about it, the oil is injected after the carburetion anyway, so it wouldn't gunk up the carby jets either, so that piece of advice is utter bollocks.
Look, ride it hard, rev it hard and I guarantee you won't have oiled plugs, tachometers have a redline for a reason, get close to it.
__________________
Desmogod is offline   Reply With Quote
Old 03-10-2008, 10:16 PM   #11 (permalink)
Stratos's Avatar
The oil is actually fed into the side of the carburettor on the 125's Jim. However, i cant see how it would block unless it was burned. The only thing i have ever ever seen block a the ports in a jet are the tiny tiny bits of shit from our crappy fuel that gets past the filters.
Literally these bikes are a 125 race bike with lights and a license plate whacked on it, and some shitty Euro 2 controls (post 2005).
Ride the cunt hard, she wants to be thrashed. They loosen up, the feel "free'er" after a good hard run. (freudian)
These things max out at 165kph. Try it tomorrow n get back to me.
I would have a look at your oil pump calibration though. How many K's you done on it? I can show you a few lil things to give it just a tad more whack in the mid range.
__________________
Old 04-10-2008, 02:41 AM   #12 (permalink)
CBR600RR7, 1.5x VJ22 RGV250
thro's Avatar
^^ whs.
by "ride hard" you don't necessarily need to break the law... but give it a good squirt in first/second gear as often as possible (eg, every set of lights, to redline or close to) and it should be fine.
__________________
310rwhp 180sx for sale. most bolt ons (turbo, injectors, ecu, brakes, suspension, etc), $11k. pm for details
New to riding? Or group riding?
thro is online now   Reply With Quote
Old 06-10-2008, 04:37 PM   #13 (permalink)
Aprilia RS125
well i got a new plug the old one was well past cleaning and have been giving it a good thrash no problems thus far. I have done over 2000kms so she pretty worn in. I did end up with a seized piston just after first service which was weird maybe they upped the oil when they fixed it. Ill jus keep givin it too it and see what happens so far so good.
Old 06-10-2008, 06:01 PM   #14 (permalink)
druu's Avatar
Seized piston after the first service?!
druu is offline   Reply With Quote
Old 07-10-2008, 07:36 AM   #15 (permalink)
rgvlee's Avatar
lol, what did you do... hammer it from cold?
rgvlee is online now   Reply With Quote
Old 08-10-2008, 03:05 PM   #16 (permalink)
Aprilia RS125
nah Im a a newb to bikes but Im not new to engines. Always wait till its warmed before giving it the get go. I was on way home from work heading to petrol station doin bout 60ks when the back wheel locked up. The shop never actually said what caused it but I know they had trouble with aprillia trying to claim parts and work on warrany.
Also wondering what plug should be used. The one in the bike at the time was a NGKR irridium race plug these are meant for higher temps aren't they? as in full fledged racing where the motor is really hot all the time.
Old 08-10-2008, 03:10 PM   #17 (permalink)
rgvlee's Avatar
the number on the plug is the key to the heat rating
Old 08-10-2008, 04:22 PM   #18 (permalink)
Stratos's Avatar
I used a NGK BR9XIE, the iridium ones. Would get a new one every 6000km or so.
And mate, I'd love to hear what caused the piston to seize. Thats pretty crazy after only 2000km.
__________________
Old 09-10-2008, 06:46 PM   #19 (permalink)
Aprilia RS125
I would also love to know... never know could be a lemon. (I hope not)
The race plug is a BR10EG while the other plug is a BR10EIX so the heat rating is the same I take it for both plugs? Does the heat rating go up along with number? Can anyone tell me what the difference is between them obviously the tip on the race plug is thicker. Does this just mean a more reliable spark?
Old 09-10-2008, 08:28 PM   #20 (permalink)
Stratos's Avatar
Yes, the higher the number the cooler the plug.
The iridiums produce a more 'powerful' spark due to the better conducting materials requiring physically smaller exposed conductive areas. Performance increase is negligible, but i found more response from the bike after fitting one. These plugs also pose more reliability with cleaner burns.
I traded off with the 9 being between the 8 & 10 as i didn't see myself keeping it WOT (wide open throttle) 100% of the time as i often used it to commute to work.
It performed beautifully country run or commuting. These little weapons are temperamental. Keeping a close eye on how they are running is a must!
I gather as your a noob you dont know about the CDI and RAVE mods yeah? CDI is your ignition control unit, and the RAVE controlls the actuator for tour power valve.
Your spark plug is one of the major keys in telling your how 'healthy' your bike is. Kinda like a doctor shoving a thermo up ur sphincter. Oh and btw, keeping a close eye on the cleanliness of the PV is a must! And keeping the oil pump in check too! At least every 6000km! Dump your gearbox oil every 6000km too. I rode mine fairly hard off the line, slipping the cluch ALOT so the oil dirties quite quick.
Let me look at your bike, ill make her run sweet. I miss my RS.
__________________
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
» Sponsors
» Current Poll
Work in Indonesia
Yay - 27.69%
18 Votes
Nay - 72.31%
47 Votes
Total Votes: 65
Advertise on PSB
