Results 1 to 9 of 9
Thread: RZ parts
    D.J
    D.J is offline
    Member D.J's Avatar
    Jul 2008
    Melville
    a few
    4 times
    RZ parts
    Hey all,
    I am not normally after bits for RZ's but am chasing a triple tree set (35mm) from a RZ250 or 350, anyone has one or know where I can find one.
    cheers
    DJ
    1:Which way do I go
    2:Whats the lap record.
    May 2009
    newcastle
    mito400
    6 times
    hey mate i got one gimmie a call 0406726252 thanks
    Jun 2009
    Albany
    Yamaha/Suzuki
    Hullo Dean,
    I should be able to help you out!
    D.J
    D.J is offline
    Member D.J's Avatar
    Jul 2008
    Melville
    a few
    4 times
    cheers Gents
    1:Which way do I go
    Member fredie's Avatar
    Jun 2007
    Sydney
    CX125
    20 times
    gday . twinrock is a top bloke . look after you
    Nath's Avatar
    Feb 2004
    PSB Café
    pink r1200gs
    41 times
    19 Post(s)
    If not sorted already I'll certainly have a spare set.
    Member Sean'o's Avatar
    Sep 2005
    NoR
    I also have a set or two lying around
    D.J
    D.J is offline
    Member D.J's Avatar
    Jul 2008
    Melville
    a few
    4 times
    PM's sent Also chasing a set of RZ forks from the later model (F2 I think) auto dampening.
    1:Which way do I go
    Sep 2005
    NoR
    Just went to the shed to see what i had, and had a thought. Are you after the earlier model triples with the clamps on the top plate for a single set of bars like motocross bars, or ar you after the later ones off the R models or 86 and later that take the clipon bars? I only have the earlier models, they have the two mounting points on them if you are going to be running old style guages or bracket, and a bikini fairing. These top plates are flat, the later model ones have a drop from the centre to the forks, allowing for clipons to sit on top of them, if you wanted to run clipons, then you would either have to run them under the top triple plate, or push your forks a hell of a long way through.
