Results 1 to 19 of 19
Thread: Too much oil is never enough?
    Member Uncle Flash's Avatar
    Nov 2008
    Way Out West
    Awesome Italian Scooter & Awesome Italian Motorcycle & Awesome Italian Bicycle
    17 times
    First start up of the new engine at ten second intervals:
    Too much oil?
    Please, call me Flash...
    Member ninjaa's Avatar
    Mar 2010
    Lockridge
    Aprilia RS125 (half) & cbr600 f4i (Track)
    67 times
    10 Post(s)
    Did ya spill some on the headers too? Filter tight?
    Quote Originally Posted by Gothchick View Post
    She is female after all.
    Member g0zer's Avatar
    Sep 2004
    RZ250-R
    130 times
    oil from assembly + cold motor nice spannies for a scoot
    Member aaronmvrider's Avatar
    Feb 2010
    gosford
    rz 350, rz500, mv f4 1000
    when you put the barrel over the piston did you use excessive oil
    1984 rz 350 stroker
    1984 rz 500 original
    2004 mv agusta f4 1000
    1994 mitsubishi magna wagon
    Sep 2011
    perth
    rz350
    9 times
    Quote Originally Posted by Uncle Flash View Post
    Too much oil?
    take it for a run see how you go, +1 arron, maybe residue oil from the rebuild, general concensus is to smear new pistons with some 2t before install, if its still smoking excessively check your mix/oil pump setting as per the book, if it wasnt smoking then id be woried. Unless of course your woried about the ozone.
    Nov 2008
    Way Out West
    17 times
    This was a bit of a leg-pull.
    I just rebuilt the motor with a Malossi 172 kit and noticing the new oil line wasn't full yet, I figured 5 litres of 50-1 should do it until the oil pump fills the line.
    And an extra squirt for good measure.
    And another just to be sure.
    So much oil that it's pooling in the bend and dripping out.
    So much extra oil that I'm surprised it started first time. Well, the first time I noticed someone had flicked the kill switch to off.
    Sep 2011
    perth
    rz350
    9 times
    sorted then,
    Nov 2008
    Way Out West
    17 times
    God yes, I just need to put the panels back on and run it in over the weekend.
    Then I'm out there looking for prey.
    lit
    lit is offline
    Member lit's Avatar
    Sep 2008
    10 times
    11 Post(s)
    Haha, I remember this scoot. It shat all over my 250.
    Spoiler: show
    Member Loud's Avatar
    Dec 2009
    South. Just.
    41 times
    Hmm, that's a bigger motor than my bike - and that's with my own big bore fitted!
    I used a syringe to pre-fill and prime my oil lines, though it makes for a less interesting photo.
    Member Mattis's Avatar
    Perth, NOR
    98 R1 - Blue Goodness
    Usually there is a method of priming the oil pump after you've emptied the system. Think with my old RGV you use to adjust/lock the oil pump adjustment to full open for a period of time until the lines were full.
    Can't hurt to run some premix in to start with though, just got to hope you don't foul plugs.
    Member thro's Avatar
    Jun 2006
    Wellard
    CBR600RR7, 1.5x VJ22 RGV250
    157 times
    7 Post(s)
    i did the same thing with my RGV (i.e., didn't bother to prime, ran 33:1 premix plus oil lines).
    it ran fine, but yeah a bit of smoke
    plugs were fine, but then again it got about 6km of break in before gossie GP....
    stuff
    Member agrid's Avatar
    Apr 2008
    271 times
    13 Post(s)
    I remember Holden V8s used to take a lonnnnnggggg time to pick up oil after a rebuild. Packing the oil pump with vaseline did the trick.
    Member Gangus's Avatar
    Jun 2009
    2 bangers
    9 times
    Quote Originally Posted by lit View Post
    Epic fail
    Nov 2008
    Way Out West
    17 times
    Flushed the tank, adjusted the oil feed and took it for its first run. Even on part throttle it goes like the clappers. Way faster than it used to be. It's a bit noisy but meh.
    Quote Originally Posted by Gangus View Post
    Epic fail
    Which means you'll be riding like a man possessed everytime you see a scooter coming... Just in case.
    Jun 2009
    2 bangers
    9 times
    nah...
    But I would pay to see your scooter eat my 250 for breakfast.
    Still im happy that you have got it humming though, 2t's forever!!!
    Sep 2011
    perth
    rz350
    9 times
    You should go and put the wind up Dark Shadow tomorrow, on the "spirited country run" recomedded for "big bores only". Bearing in mind youd be up against a fazer, so you might have to lean her off a bit so shes a bit punchier out of those sharp corners.
    Member Scoundrel's Avatar
    Feb 2004
    Lynwood
    2000 ZZR600
    14 times
    Quote Originally Posted by agrid View Post
    Cycling the engine with the plugs out often did the trick
    Nov 2008
    Way Out West
    17 times
    Quote Originally Posted by seahorse View Post
    The scooter's quick but only to a point. It's a great urban assault vehicle but not so good above 100kph. Where it does well is around tiny roundabouts and down alleyways. In fact, everywhere my Ducati is not comfortable.
    The smoke has eased off but it's still a bit rich. The heavier clutch springs have made it a touch on or off. Tomorrow I'll spend a couple of hours with a handful of jets. Loving that smell.
