Picked this up from eBay in the UK. It's a pressure bleeder and falls into the "why didn't I think of that" category.
[IMG][/IMG]
[IMG][/IMG]
It comes with four different size caps for common master cylinders. They don't fit most bikes so you make your own. You can drill a 10mm hole in your original and put a plug in it or get hold of an old cap. I got an old cap from Clutterbuck Speedworkz. They have a range of old caps for $6.50 each or $16.99 for two.
Procedure:
1. Suck out fluid from master cylinder with a syringe or siphon out.
2. Fill master cylinder with new clean fluid.
3. Let down one of your tyres to 20psi or use a car tyre or whatever.
4. Fill pressure bleeder container about 60% to 75% full.
5. Screw cap tighly onto master cylinder.
6. Connect pressure hose to tyre valve.
7. Connect bleed hose to each bleeder and bleed off fluid in the normal way into a container until new fluid comes through and no air bubbles are present.
8. Release pressure and remove the modified master cylinder cap.
9. Check fluid level and fit normal cap.
I've done my Vito Van and the bike. Many of the modern ABS equipped vehicles advise that pressure bleeding like this is the only way to do it properly.
It cost about $45 delivered.
Scott
[/IMG]
[/IMG]
