Results 1 to 4 of 4
Thread: clutch oil questions
    New Member
    Mar 2010
    michigan
    honda's all the way
    Smile clutch oil questions
    1982 honda cr250r elsinore, finally got the clutch figured out (ihad it adjusted completely wrong), now i dont now what kind of oil to use for the clutch or how much to use, do i fill it right up completely?
    thanks to everyone who has responded to my clutch problems, appreciate all the info and now its just about ready, just need new gasket for clutch casing and some oil. ???
    should i use midgrade or regular fuel?
    Member jules_1972's Avatar
    Ducati 998, XR600, Ducati 999R Track, Ducati 900SS
    3 times
    WTF???
    Oil question then fuel????
    Bizarre!!
    Jun 2005
    When purpose made 2-stroke trans oil isn't available, you can use a 15w/40 oil and it won't matter whether the formulation is mineral, synthetic fortified or full synthetic. Don't use a car formulation as some have friction reducing additives that will cause slippage. If you have access to a bike shop, any brand of 2-stroke trans oil will do the job ( but change it regularly even if not racing). From memory, 750ml on a 250RC. Cant remember if they have a check bolt or dipstick, either way, go with either of these for safety. Use the highest grade of pump fuel you can get your hands on too.
    MODERATOR Arwon's Avatar
    Aug 2003
    PSB Cafe
    YZFR1
    29 times
    use auto tranny fluid in the old bikes. we used to use the DEXRON III for our motox bikes.
    Belray light viscosity oil is a constant 15 weight oil for a wet multiplate clutch, the same as you have in your bike.
