Page 1 of 4 1234 LastLast
Results 1 to 20 of 61
Thread: Dual headlight conversion for kawasaki's
    Member Joker's Avatar
    Mar 2005
    East Perth lockup
    STICKY THIS as i wont explain it again.......
    this mod will work for ANY kawasaki that has one the low beam as the left light........ it took me a while but i figured it out. here is a write up on how you go about it.
    well, Sista said she was annoyed that Kawasaki in their infinite wisdom made the left light only for low beam. so whilst she is away in Europe (with her permission ) i decided since i am off work to fix the problem.
    heres what you need for a start....
    a 5 pin, 30A relay (if you dont use a switching relay, you WILL melt your plugs, wiring harness and be up shit creek)
    2 x H4 socket plugs for headlights
    2 H4 bulbs ( the one on the right is the stock h7, notice the difference in size. We are going to have to modify the H4 to fit into the stock headlight)
    Tin snips
    and finally some wire strippers, electrical tape, and needle nose pliars.
    First remove the headlight
    (if you need pics for how t do this, do not do this mod. It will be way above your mechanical ability)
    next, remove the two circle covers on the back of the housing
    pull the sockets off the headlights, remove the rubber circle in the center of the headlight and pull the wiring out throught the hole
    now youll notice the h4 is too big to clamp into the housing, so take the tin snips and start cutting down the bracket on the bulb. Your going to have to cut off the outer lip, just keep trimming small amounts and checking to see when it fits. Yo have to remove the cone inside the housing on the low beam side. I reccomend baking it in the oven and removing the front glass to pull it out. Or you can use a heat gun or clow dryer to heat up the glue and pull it out. I just held it with a pair of needle nose pliars and started butting at it with the snips untill i wa able to bend it throught the hole but i did scratch the reflector housing a little. You can only see it when you look real close.
    Wire in the H4 plugs with the ground, low beam and high beam wiring plan (once again refer to manula if you dont know this)
    replace the covers
    now follow the wiring diagram. Do not cut off the harness! you are going to connect the stock plug on the headlight harness into the stock plug on the bike. Cut off the headlight bulb harnesses and splice those into the relay wiring.
    Make sure to cut off the rubber cover so you can re use it. You only want to cut the center so it is a single hole and slide it off the old wires.
    Run the new wires through it
    Tape all your connections
    Put the headlights back in and enjoy!!
    Headlights on and back together
    Low Beam
    High Beam
    Member BigTim's Avatar
    Mar 2006
    Tiller
    10 times
    Nice write-up mate.
    Looks shit hot too.
    FTP
    Member foolishboy's Avatar
    Nov 2006
    Nigeria, Can you help me.........
    Ducati 1098
    3 times
    Awesome job there Joker, hmm got the same problem with my 'blade, would be nicer if both headlights lit up.
    In Kazakhstan if you want sugar in your coffee you ask for Kunt
    Member DRKSIDE's Avatar
    Nov 2003
    The land before time
    hydrogen-powered foozeball table
    Excellent job Joker. Youve explained it really well
    Damo
    Member Orson's Avatar
    Esky Scooter
    73 times
    I'm blessed in that my model of bike is already equipped with dual (H4 also) headlamps. But still wanted to congratulate you on taking the time to do that Joker. I'm sure there are a tonne of peeps who'll be ever grateful and use your advise on this mod. Now you can look forward to wankers flashing you cos they think you've got your H/Bs on. Then they really cop any eyeful when you flash them back with your actual high beam. he he he. Once again, good job
    Quote Originally Posted by Xavier Lefaux View Post
    Redheads are my kryptonite, so I guess I'd have to trust them, but the hand jobs might feel weird.
    Stu
    Stu is offline
    Member Stu's Avatar
    May 2005
    Bayswater
    Ducati 1199
    13 times
    Top write up Joker.
    Spiral out, keep going...
    Mar 2005
    East Perth lockup
    thanks for the replys guys....... i am pretty positive the girly will love it
    oh, and took approx 5 hours (cause i have never puled a Kwaka apart b4) and cause i had to remember my relay theory
    Member Hornet's Avatar
    May 2008
    Scarborough, WA
    '06 Yamaha R1SP | '09 Suzuki GSX-R1000
    39 times
    14 Post(s)
    PICSOFSISORBAN.
    Good write up... I know a guy with a 'Blade that might be able to use that for his.
    My nemesis; Barfridge
    Quote Originally Posted by Deej View Post
    I dont believe that Stoner will be the World Moto GP Champion ever again.
    Amen, brother. Amen.
    Mar 2005
    East Perth lockup
    hahahha thats her mum in the background Hornet
    she is in Europe at the moment, which is why i am pulling her bike to pieces hehehehe
    May 2008
    Scarborough, WA
    39 times
    14 Post(s)
    Her mum?
    Ooer... don't mention that word around here... Savi might hear and that wouldn't be good for anyone.
    Nice to play with other people's toys while they're away, aint it?
    Mar 2005
    East Perth lockup
    SURE IS!!!!!!
    she said on her wish list was a fender eliminator, and to somehow get the low beam on both sides..... i have achieved both
    with a broken shoulder too hahahaha fucking hurt it a lil today tho. whoops
    and yeah, the mod should work on a blade, but the wiring will be a lil different (makes of bike diff) but it shouldnt be too hard to figure out
    Member Dave M109R's Avatar
    SOR
    Big V-Twin
    16 times
    Top work Joker, might use this in attempt to do the 10.
    Might be a bit harder though, different lenses.
    Good write up.
    Judge the character of a person by the way they treat people who can do nothing for them.
    Member Viper's Avatar
    Mar 2007
    Ellenbrook
    06 Ninja ZX-6R 636
    56 times
    8 Post(s)
    i'm gonna do this and the HID conversion at same time. I'm ordering in a HID H4 BI kit and doing this mod. I'll take some piccies along the way.
    Might be a couple weeks though
    Member Twinks's Avatar
    Aug 2006
    High Wycombe
    Black one and a blue one
    Yeah very cool write up. Might stop every second person telling me i have a headlight out.
    And its always good to have someone work it out for ya.
    Milk, milk, lemonade, round the corner Adelaide
    Mar 2007
    Ellenbrook
    06 Ninja ZX-6R 636
    56 times
    8 Post(s)
    oooops
    Member Bunyack's Avatar
    RiVerVale
    '03 YZFR1, '93 CBR600F2 STUNT PIG!!
    25 times
    12 Post(s)
    great right up. one reason I dont like a lot of the newer model bikes is this reason.
    Have you won the game recently?? Post here
    Mar 2005
    East Perth lockup
    Bump, for newer members with the 1 headlight problem
    ps:- currently doing a writeup for a Dual headlight HID conversion for an 06 ZX636LE... did it to MrMez's bike
    Member Pobbler's Avatar
    May 2008
    Como
    ZX10R
    I did mine a year ago... best mod ever!!
    the grass is greener on my side
    Inactive Member B.six's Avatar
    Jun 2008
    south perth
    Yammie R6 '05
    1 Thread(s)
    bah iv been looking into it 4 my R6 because the ports are already there for the globes so it can have an R1's light config. From what i can gather from the yanks tho its a bit of cutting and grinding and i was never good with electrics....i remain 1 headlight out
    Is this workable joker?-
    http://www.palehorsecycles.com/howto.pdf
    Member MattyA's Avatar
    Jul 2008
    Cuttin Ya Grass With Ma Bike
    FZ6n & '78' TY175 Resto
    7 times
    a tad off topic but can you up the wattage of standerd 55/60 gloves to higher ones without fear of melting the reflector/housing?
    or hang a couple of dirty big spotlights from the forks.....
    ^fugly
