Results 1 to 7 of 7
Thread: Fuel Gauge 2007 Hyosung Aquila Gv250
    Member slynch's Avatar
    Aug 2011
    2007 Hyosung Aquila GV250
    Red face Fuel Gauge 2007 Hyosung Aquila Gv250
    G'day Motorcycle Gurus,
    I've been looking through the "how to's" and I'm still yet to find a solution to my little issue.
    It appears the fuel gauge on my motorcycle (2007 Hyosung Aquila GV250) is stuck on "full". It's not really a big issue, because I make sure I fill up every 200-250km, but as some-what of a perfectionist, it's annoying me.
    Now, I'm aware it could be one of three things,
    1. The gauge itself (This seems likely, seeing as it sticks on 'full' when the ignition is off)
    2. The wiring.
    3. The sender.
    I'm mainly after some advice on how to repair/check these things, I've been all over google and found nothing helpful, yet... Maybe one of you have had the same issue and may have some helpful advice for me?
    Any help would be greatly appreciated.
    Thanks, people!
    - Tom
    Member kenty's Avatar
    Aug 2008
    Perth, Beechboro
    2010 YZF-R1SP
    15 times
    silly point but have you tried gently tapping it ?
    Master of the missed signals
    Aug 2008
    Perth, Beechboro
    2010 YZF-R1SP
    15 times
    also does your bike use a float, or is it electronics?
    Member CanAm's Avatar
    Aug 2010
    GSX750S - GT650R - XN85D
    Try having a look on korider.com and see if anyone there has had the same problem??
    Moderator Rich's Avatar
    Apr 2006
    Perth...Home sweet home...
    419 times
    42 Post(s)
    If you can disconnect the wiring near the gauge you could then check continuity and resistance of the wiring and level mechanism with an empty and full tank...
    This will let you know if you have a jammed level mechanism as the resistance should change from empty to full...
    If that checks out then you can assume it's the guage and go from there...
    Aug 2011
    Thanks for the suggestions, guys. I have a day off tomorrow and will be performing a full maintainence (including the fuel gauge). Will let you know how it turns out.
    Cheeerrrrssssss
    Aug 2011
    Ended up taking the gauge apart, and unsticking the needle. Just a little of WD40, and the problems solved.
    Cheers, guys
