Originally Posted by
Paraletic
Higher loads / wider throttle will increase combustion pressure, thus putting more force on the rings, thus more scraping the bore. while this is great for bedding them in the walls are not getting lubricated too well as the hight spots (just what running is is trying to remove) will be scrapped dry and will scuff if held like that for too long. but also the opposite is true where not enough pressure on the rings will not remove the hight spots, thus allowing blow by, oil burn, and polishing of the bore.
remember the abrasive nature of the fresh metal does not last long and there is not much you can do to rectify this once it has occoured. (yes there is a trick with ajax powder, yes it does work.)
the reason for changing your rpm and keeping it around mid range, and not idling too long, is for your camshafts / valves. at low speeds
(below about 3000 rpm) your lifters will not rotate, and if your valves dont have rotocoils (most wont), neither will they, thus wearing on the same spot (remember newtons law, f=P*A,) and if its there for too long it will score and scuff till it will never rotate causing premature failure of the valvetrain / camshaft. or in the case of valves, this can result in overheating the valve and burning through it, and sealing badly.
so basically changing the load frequently, (and do load it up abit,) will remove high spots, then allow for lubrication will do a treat on your bores. And changing the revs to keep the lifters and valves rotating.
And yes, i am a Mechanic.
