Results 1 to 15 of 15
Thread: How do I fix Vibrating Mirrors?
    Member LouER6N's Avatar
    Mar 2009
    Morley
    Kawasaki ER6N
    The mirrors on my ER6N vibrate quite a bit anything above about 40km/hr and at 60-80 they are all but useless. The mirrors are not wobbly or loose, everything is blurred in them. The previous owner added an extra nut to try and dampen the vibration but it didn't help. They put renthal bars on the bike too. I've asked at the Kawasaki dealers what I can do but didn't really get much joy. One suggested trying mirror extensions but at $90 for the pair I didn't really want to spend that much if it wasn't going to work.
    I know I have to expect some vibration but I'm hoping someone can suggest something that will make my mirrors a bit more useful!
    Apr 2009
    shenton park
    None :(
    might be silly but if you added a rubber insert where your mirror bolts onto the bike could it take some of the vibration out?
    Member millsy's Avatar
    6 times
    are they original mirrors? sometimes OEM is fine and aftermarket replacements have this problem..
    This post is now diamonds! I'm on a horse.
    Member Shady7/8's Avatar
    Oct 2008
    ***CLASSIFIED***
    User is a dirty Perve
    249 times
    Try weighted Bar ends if the above suggestions fail...
    If at end of tether for ideas, fill the bars with Lead shot. Should take most vibration out of the bars
    Keep up to date with my Everest Trek here! http://your-everest.com/
    Raising awareness, and donations here - http://www.everydayhero.com.au/youreverest
    Quote Originally Posted by Martin Luther King Jnr
    Cam
    Cam is offline
    Member Cam's Avatar
    Dec 2006
    Mundaring
    644 times
    32 Post(s)
    ER6n is notorious for rattling up front like that. It's character.
    Rubber mounts could help reduce it.
    Member Rizzo's Avatar
    Feb 2008
    Southpark
    2010 YZF R1SP
    21 times
    Was gonna suggest weighted bar ends or a rubber mount if possible, but since they have both been done, try dropping down a gear get out of that rev range and that might help, it works on the r1.
    TEAM KL 2013
    R.I.P Super Sic 58
    Member likefry's Avatar
    Oct 2005
    Leeming
    GSX600F
    9 times
    To reduce vibration you have to either increase the mass of the mirror or decrease the stiffness of the stalk.
    easier to increase the mass of the mirror by gluing s a weight on them.
    Wes
    Mar 2009
    Morley
    Kawasaki ER6N
    Thanks for your suggestions. I'll give them a try over the weekend. I seem to remember the previous owner telling me they had filled the bars with sand. When i did an internet search there were a few comments about how bad the mirrors can be but I had a 2009 ER6N as a loan bike last year and it didn't seem so bad. Any improvement would be a bonus. I think the mirrors are OEM. Anyway a project for the weekend.
    Member thro's Avatar
    Jun 2006
    Wellard
    CBR600RR7, 1.5x VJ22 RGV250
    157 times
    7 Post(s)
    get an inline 4
    mirrors are overrated anyway, head checks...
    stuff
    Jul 2009
    Willetton
    Kawa zzr250
    Remove the battery? jks
    Or get a rubber "O" ring and stick it on the bolt to absorb vibrations....if that makes any sense
    Quote Originally Posted by thro View Post
    head checks
    This.
    Success is nothing more then taking advantage of an opportunity.
    Mar 2005
    The Southwest where it just keeps on raining.........
    Hi Lou;
    I've got an 09 Versys with the same problem (funny that...).
    I've just fitted the Motowerk mirror widening kit and not only can I see past my big fat shoulders - the vibes have disappeared to a large degree. I think its on the basis of what Likefry said above about decreasing the stiffness of the stalk by adding another element to the base.
    Might be worth a try on your ER??
    Grumpy
    Nov 2008
    Girrawheen
    ER-6n.
    There I was about to do a search on vibrating mirrors on kawasaki's and here is this thread at the top of the page already.
    650P has the same problem. It does promote head checks as Thro suggested. I was curious to see WTF the big silver blurry thing was in the mirror.....Oh look, its a land cruiser!
    Member Helipos's Avatar
    Dec 2009
    St James
    Husky 510, KTM SuperDuke
    Probably made worse by the renthals, If you can get the stock bars back on, they are probably not as stiff.
    Cam
    Member Dinga's Avatar
    May 2009
    Willetton
    K6 GSXR1000
    Take them off throw them away and look over your shouder instead
    Member MattyA's Avatar
    Jul 2008
    Cuttin Ya Grass With Ma Bike
    FZ6n & '78' TY175 Resto
    7 times
    yeah get the renthal superbike bars. my fz6 was bad for this when i changed the bars to pro tapers. (dirt bars) then i got the renthals which are road. now i dont even need bar weights.
