Results 1 to 18 of 18
Thread: how to get petrol tank open without a key ?
    Oct 2010
    adelaide
    yamaha sr250
    I have a Yamaha SR250 im trying to bring back to life. I have the ignition key but no petrol tank key.
    Any ideas on how to open the tank without damaging the tank itself ?
    Or is the best bet just go to a locksmith of some sort ?
    I have not tried the screwdriver and hammer method yet.
    Thanks
    Moderator Barfridge's Avatar
    Feb 2005
    ZX-7R
    822 times
    52 Post(s)
    Are there allen headed bolts around the tank? If so, sometimes you can undo those and then lift the whole lock out.
    Otherwise you might need a locksmith to make a new key to suit the lock. Or it could be cheaper to go to the wreckers and buy a matching set.
    Member Brendonv's Avatar
    Apr 2010
    Ballajura
    Suzuki DRZ250 , Suzuki TS185
    Dont attack it with a screwdriver and hammer please.
    Member BlaznGSXR's Avatar
    Oct 2009
    Queens Park
    K8 Gsxr 750
    Maybe the locksmith can re-key the lock so that it suits the ignition key?
    CBT
    CBT is offline
    Member CBT's Avatar
    Oct 2009
    Ascot WA
    Bimota YB8, GSX11 resto, GS1000S and T250 Hustler projects
    6 times
    I would try some WD40 in the fuel tank lock and leave it for a few days then give a try with the ignition key. You might find that it has simply jammed up.
    It worked for me on my project bike.....so you might be lucky too.
    Member rharris's Avatar
    Sep 2006
    bedford
    on the side of the road
    74 times
    19 Post(s)
    Take the tank to a locksmith if your ignition key go into the tank lock get them to rekey it to suit , a fair price will be around $50
    Member Dog Loaf's Avatar
    Aug 2005
    DEEP SOUTH of river
    Shank's Pony
    i think you might be able to grind or oxy the cap off..............
    leather coated squid
    Member Pinkee's Avatar
    May 2004
    Tiller, zx10r-broke or track hmmm, cbr2fiddy-RIP
    25 times
    5 Post(s)
    hahaha. oxy the cap off a FUEL tank?!? BOOM ftw!
    most locks clip down to the lip of the tank itself. so the allen bolts wont help (they are just there to support the hinge). like the others said. locksmith would be your best bet.
    Member agrid's Avatar
    Apr 2008
    271 times
    13 Post(s)
    Seems unlikely that the ignition and tank would have different keys without the previous owner letting you know, I'd keep lubricating and fiddling ... er and stay away from anything that has flame or sparks.
    Member House's Avatar
    Jun 2006
    Right here
    GSXR 600
    Quote Originally Posted by Pinkee View Post
    BOOM
    Funnily enough a punctured fuel tank won't explode if it still has fuel in it, too much petrol vapour and not enough oxygen inside (yes, movies lie). Obviously can still catch fire at any openings though.
    An empty fuel tank with a bit of vapour still in it on the other hand...
    If you ever do need to cut something that has previously had fuel in it, remember to fill it with water beforehand. It's most dangerous when empty.
    Mit viel Oktan und frei von Blei,
    Einen Kraftstoff wie Benzin
    May 2004
    25 times
    5 Post(s)
    Quote Originally Posted by House View Post
    or carbon monoxide... welded up a tank once... used a vaccuum hose from a running car exhaust straight into the tank...
    Member g0zer's Avatar
    Sep 2004
    RZ250-R
    130 times
    What if you remove the fuel tap assembly? Can you manipulate the catch from the inside of the tank to pop it open?
    Jun 2006
    Right here
    GSXR 600
    Exhaust is almost entirely the dioxide, thankfully. Carbon monoxide is rather flammable.
    [/science sperging]
    Having a constant stream of a non flammable gas into the tank is a good idea though.
    Also, back on more sensible topics, g0zer has a good suggestion there.
    New Member Krusty1's Avatar
    Aug 2010
    SOR
    RZ's & a GSXR
    Let me know how it goes coz I got the same problem.
    I've got an old POS project that I ain't gonna look at for a while but.
    Ignition & tank aren't keyed the same. No tank key
    D.J
    D.J is offline
    Member D.J's Avatar
    Jul 2008
    Melville
    a few
    4 times
    Yamaha? 4 digit number on lock? these guys may be your friends
    YH5R Key Blank | YAMAHA | Motorbike | Vehicle Keys | www.keytrader.co.uk
    Let me know your number I may have the one here.
    1:Which way do I go
    2:Whats the lap record.
    May 2004
    25 times
    5 Post(s)
    haha whoops. my bad, meant to say dioxide... had monoxide on the brain for some reason.
    Member bigmak's Avatar
    Jun 2008
    warwick
    636, cbr 600, kx250
    oxy torch or grinder. MUST have fuel in tank for this to work properly
    Member BikeRider's Avatar
    Mar 2010
    GSX1400 & GT650S
    9 times
    Quote Originally Posted by Brendonv View Post
    The hammer and screwdriver worked fine on the old Katana. It was already partially damaged by some Arsewipe when it was parked at the Entertainment Centre many years back so no loss, the question is, do you want to keep the cap or can you replace it?
