OK, thought this might interest some of you out there...
So you have a 199X/200X CBGSXYZKRRRR-RR, and suddenly bad noises are heard from the engine, and it doesn't go so well anymore... S#!7 F@©K etc, etc. Your choices
1) Run off the road into a tree and write the bugger off, get the insurance money and buy something new (illegal and potentially/most likely dangerous)
2) Put on truck, drop off and mechanic and organise to sell a kidney to pay for whatever went wrong to be fixed
3) Put on truck/friendly PSB'ers trailers, get it home, and fix the bastard yaself!
So, my daily commuter, a 1996 GSXR 750 decided to make some bad noises, seconds before it decided to become very very hard to turn over... Bollocks. Option 3 it is, and here is the rebuild/rough guide to doing it yourself.
Step one: Get bike somewhere you can work on it. There are a few threads already on tools/garage setup, check these out. Lift is nice, but a solid rear stand is enough.
Step two: Get informed, find/download/buy a workshop manual, if you struggle a bit get a haynes/clymer manual as well. Check out forums, find out the regular weak points of your bike, things you will likely want to check or replace while its it bits.
Step three: Clean! Pull fairings off, and clean the engine. Any dirt on the engine will end up in engine. If your planning on pulling it down completely and putting the whole thing in a parts washer this isn't so important.
Step four: Purchase the most important items you will ever find in your toolbox, the three things that I simply would not dare to begin a strip down without...
Yes, snap lock bags and white and black textas (black sharpies are great too).
Step five: Begin! Set up in a comfortable workspace, and begin the strip down as per the workshop manual. Bag and tag everything, box up large items (eg clutch assembly). Lay down cardboard/paper when stripping to contain mess, and make it easier to find small washers, screws that always bounce away...
Step six: When it is pulled down as far as needed, inspect. Measure, looks, take parts to an engineer to measure, crack check, test straightness. Whatever it needs. Pay attention to weak points you noted earlier.
Step seven: Make a parts list, with EVERYTHING you will need, from bolts to bearings to gaskets to crankshafts (not kidding...). Don't forget things like loctite, gasket compounds, assembly lube and regular consumables like oil and filters. Price it up, hunt on ebay, wreckers, UK and US sites (love the weak pound and dollar...), find the cheapest way to obtain the parts. While talking to wreckers, ask about complete engines. Compare prices, and weigh up where to go. For a similar price, a rebuild is usually the better option, since you know it's now going to be 100%, if a rebuild is going to costs $4000 because a conrod took a holiday via the front of your crankcases, maybe a wrecker engine is a good idea...
Step eight: Assuming your rebuilding your engine, get all the parts you need together. Clean everything, grease/oil and wrap till needed. There are spray on light oils (Inox etc) which are great, stop things rusting and leave a thin film of oil on them. Catering roll of clingwrap is great for keeping parts clean till you need them.
Step nine: Assemble, as per your manual. A big box of rubber gloves is handy at this point, you can't be too clean. Main and big end bearings typically have 1-2 thousandths of an inch clearance, thinner than a ciggy paper, it doesnt take much to ruin it.
Step ten: Return engine to bike, as per manual. Refill fluids, etc and hook everything up. Follow your manual for first startup, normally you will leave plugs unhooked and crank it over a few times to get oil pressure up. For the first startup, make sure the bodywork is off so you can check for leaks.
Step eleven: Put it all back together, break in as per favourite method
So, there is the rough outline. And to follow will be details of me working through each stepEnjoy
1Likes
