Page 1 of 6 12345 ... LastLast
Results 1 to 20 of 103
Thread: Howto: DIY Flamekit Project
    Member Eukanuba's Avatar
    Aug 2005
    kwinana, k-town, AKA redneck county
    Racing Dinghy
    Ok, after taking an interest in 'afterburning' as seen in ' the fast and the furious ' and ' batman '.. I decided to do some research.
    I decided to install a flame out kit for my bike, why ? because I wanted to.. in theory - it'd be safer than just a regular 'keybang'.. so I set out on my mission to install one..
    Disclaimer: Note, this device and modification to my vehicle - is only going to be used at approved facilities - i.e. motorplex, and is not authorised nor intended for use on public roads.
    It is not my intention, nor purpose to break any laws applicable to the use of this device - so if you're a police officer trawling for information, the copyright on these pictures belongs to me - and may not be saved, downloaded or used without permission from me, if you do - you are breaking the law - and I keep logs on my domain/server of I.P. addresses complete with time stamp.
    Now, that's over with.. onto the juicy bits..
    Step 1.
    Read the instructions, read them again.. and then, check again to make sure you've not missed anything..
    Step 2.
    Find a location to mount the 'control module'
    Must not be allowed to earth against a metal frame, so my 'glovebox' was perfect for this.. and i wasnt using this space anyhow..
    This box came with double sided tape, no additional drilling required.. easiest part so far..
    Step 3.
    What we have here, is an automotive ignition coil..
    a +ve side, a -ve side.. and a High tension line out.. that runs to a spark plug....
    Step 4.
    Connect the blue wire, from the control box - to the ignition coil +ve screw..
    Step 5.
    Here's the next part, selecting a 'drill point' in which we shall mount the ignition device.. also known as a spark plug.. ( note, the can is off the pipe.. )
    Step 6.
    Commence the drilling !
    and here's the drill...
    Step 7.
    Here, the plug is in - it's a 12mm hole..
    Lead is on the plug, and the securing nut is in the pipe.. holding the plug in place..
    Step 8.
    Secure the high tension lead..
    Step 9.
    Here's what it looks like, 'down the pipe'
    Step 10.
    Now, to decide where to mount this coil..
    In the glove box will waste valuable space that I use for my first aid kit.. Mobile phone, neck warmer.. etc.. so i dont want some filthy big coil sitting in there...
    That mounting place for a reg/rec looks good..
    But, after all is said and done.. the fairings need to go back on.. and - this proved a problem..
    Step 11.
    Check the wiring isnt pinched, that's running through the glovebox.. dont want a pinched High Tension lead direct to the frame..
    Step 12.
    Mount that switch..
    Step 13.
    Run the earth from the control module, to the frame..
    Clean up those ties..
    All starting to come together now..
    Step 14.
    Right, lets move that coil to some place it will fit..
    Wrap a piece of demim material around the coil so that the ratchet ties hold the slippery surface a bit more snug, and it now partially sit's inside the frame.. more secure..
    Hook the -ve terminal on the coil, to earth on the bike..
    Step 15.
    Didn't get a photo of this stage, but it involved splicing the line from the ignition coil and wiring a switch between.. also, wiring 12V dc and a fuse from the battery to the switch.. and the trigger line from the control box to the switch.. then put all the fairings back on..
    I'll finish taking the rest of the photo's and post up soon..
    Last edited by Eukanuba; 27-01-2008 at 11:18 PM. Reason: fixing picture [img] code.. showing links only
    Come and see us in the 2011 Avon Descent - we're racing boat #234 !
    Member -stealth-'s Avatar
    in da hills
    hoonda
    11 times
    so when i need assistance from road rager cagers i know who to call....looking forward to seeing the finishing project
    Member Dave M109R's Avatar
    SOR
    Big V-Twin
    16 times
    nice work there euk, can't wait to see some flamer shots
    Member mekon's Avatar
    Canning Vale
    2007 R1, 2003 DRZ-400
    378 times
    23 Post(s)
    1 Thread(s)
    Cool, ^^whs^^ bring on the after shots. I remember keybanging an old cortina and a few ford noddy vans, was good fun, right up there with the old acetyline bombs.
    Quote Originally Posted by Abuse this View Post
    Get a load of this pussy, he wouldn't travel back in time to murder a baby.
    Member Kryzaach's Avatar
    Sep 2007
    Sinagra
    '07 CBR1000RR
    16 times
    oh noes, browsing this thread resulted in HTTP_GETs for those pics, i wasn't stealing them i swear, please don't use your interweb skillz to prosecute me.
    P.S. Awesome Idea, just don't test it if I'm behind you!
    "In all the human societies we have ever reviewed, in every age and in every state, there has seldom if ever been a shortage of eager young males prepared to kill and die to preserve the security, comfort and prejudices of their elders, and what you call heroism is just an expression of this fact; there is never a scarcity of idiots." -The Culture
    Inactive Member Mongrel11's Avatar
    Sep 2007
    Ellenbrook
    1995 Suzuki GSXR1100 Streetfighter, 2001 Kawasaki ZX9R
    Marshmellows anyone???
    Jarrod
    Handled by one.... Feared by all
    Member Insane's Avatar
    Apr 2005
    Perth - the Midlands
    2007 VFR800 Rothmans
    Sounds really good..
    I'm guessing the MO is flame-out ON.. key OFF.. burn off all the fuel in the can.. Now turn key back ON.. Oh dear me.. fuel in headers goes bang.. fuel in can is still burning..
    What happens when bang meets bang..??
    Fitted up a car (pygmy van) in my youth.. was the same set-up. with the exception of a metho/kero venturi pick-up.. No key OFF.. helluva batman flame...
    Norm
    Its a Tour not a Race - Just don't get in my way when I'm Touring.
    OzVFR.net MGP Tipping Mews News
    Dead man walkin' Davey's Avatar
    Nov 2006
    Heathridge
    36 times
    Pretty sure the key stays on - just burns off unburnt fuel in exhaust
    Member Hired_goon's Avatar
    Dec 2005
    Kelmscott
    XS 1100 x 2.5
    Quote Originally Posted by Davey View Post
    There'd be plenty of that in Honda pipes.
    To be old and wise you must first be young and stupid.
    Quote Originally Posted by PSB Forum Software
    Sorry, no matter how much you try, you can not ignore yourself.
    Aug 2005
    Racing Dinghy
    On the money Davey !
    The pressure of the 2 other cylinders firing pushes the vapour out - so it's not 'sitting' in the pipe waiting for the ignition.. so you get a continuous flame..
    So, technically not a 'bang' per se.. just a flameout..
    Member browncow's Avatar
    Sep 2007
    SoR
    62 times
    27 Post(s)
    I threads like this.....
    Flameon Euk. Can't wait to see the action shots.
    Canning Vale
    378 times
    23 Post(s)
    1 Thread(s)
    Next projects for Eukanuba...
    1, A compact swivel mount rotary tracking shotgun for firing backwards at traffic.
    2, Pillion ejector seat for those times you get bike-jacked
    3, revolving James Bondesque numberplate
    4, Full stealth fairing which reflects multanovas and radar (bike appears invisible)
    5, Light refracting surfaces on bike for similar effect
    6, A liquid nitrogen cooled drink dispenser (Camel pack type thing)made in the subframe (like a Buell fuel tank)
    7, A mortar pod that fires forward to remove road obstacles up ahead.
    8, Saddle mounted sidewinders
    9, spikes on the wheel hub to slice car tyres
    10, A Vertical Assisted Lift Off jet or something for instant wheelies at any speed
    Me want flame pics
    Member esquire's Avatar
    Oct 2007
    Shenton Park
    '99 R1 Fighter
    Thinking of putting one on my car. Only $100 and they look awesome.
    Feels good man.
    Member BigTim's Avatar
    Mar 2006
    Tiller
    10 times
    I can see you booting the fuck out of that spark plug and snapping it off within a month.
    Please report to this thread, for further rice-ification.
    FTP
    Member jonnyking's Avatar
    Sep 2006
    Rivervale
    GSXR600
    HAHA SWEET! can wait to see working pics
    Banned User
    SOR
    K6 GSX-R 1000
    Nice work Euk.
    Cant wait to see it in action.
    Member foolishboy's Avatar
    Nov 2006
    Nigeria, Can you help me.........
    Ducati 1098
    3 times
    Gawd damnit Euk, I just ordered a flame thrower kit for my blade 2 days ago, now it should be easy to fit thanks to your awesome write up YaY!
    Oct 2007
    Shenton Park
    '99 R1 Fighter
    Where did you get the kit from?
    Feels good man.
    Cam
    Cam is offline
    Member Cam's Avatar
    Dec 2006
    Mundaring
    644 times
    32 Post(s)
    Thread is useless without action pics.
    Member Biggles's Avatar
    Jan 2007
    C-mizzle
    Nine five fizzle, nine two nizzle
    haha, cool
    Quote Originally Posted by Cam View Post
    +1
