Results 1 to 3 of 3
Thread: FS (SYD) Motorised Bicycle Bike Engine Kits
    Apr 2010
    Its brand new, comes with everything you need to get it fitted. Please note, only the engine is forf sale. Not the actual bicycle.
    Its a easy way to convert your bicycle into a motorcycle . Excellent alternative if you have lost your license etc.. And excellent to get you from A to B.
    Its CNC machined and reaches approx 45-50kmh.
    Some specs and photos below.
    Price: $250.00 pickup welcome from Sydney. Or add $10.00 for delivery Australia wide.
    Poweful 66cc Single Cylinder Engine
    A80 Type
    Air cooled Engine,
    2 stroke Gasoline Engine
    Bore & stroke 47mm*38mm
    CDI ignition
    Power 2.2kw/6000rpm
    Compression ratio 6:1
    Pedal start
    2 stroke lubrication
    Fuel ration 16:1, 20:1 after running in
    500km running in period
    Tank Capacity 2L
    Fuel consumption 3L/100km
    Rub Bloc Dry Clutch
    Example:
    bicycle engine kits fitted - Google Search
    Member Shady7/8's Avatar
    Oct 2008
    ***CLASSIFIED***
    User is a dirty Perve
    249 times
    Where's the carby?
    Keep up to date with my Everest Trek here! http://your-everest.com/
    Raising awareness, and donations here - http://www.everydayhero.com.au/youreverest
    Quote Originally Posted by Martin Luther King Jnr
    Apr 2010
    Hi mate.
    The carby is in the photo below. Also take a look at the pic where the engine is assembled the carby is positioned at the top. Instruction manual is included.
