Power Commander lll USB FOR SUZUKI GSXR 1000 K7-K8 $125.00
Used but excellent condition, mapped to suit full Yoshi exhaust system with filter upgrade etc. (was producing 170+ RWHP)
-Will possibly need dyno run to set up for your own bike
What Power Commander III USB Offers
Features
Hassle free USB communication - The Power Commander USB will instantly and automatically connect to the Power Commander Control Center software once it is installed. Simply "power up" the unit and connect the supplied USB cable to the computer and PCIII USB.
Onboard notes storage - The PCIII USB stores the notes from the map in the onboard memory. This makes it easy to see exactly which map is loaded. The notes, just as the map itself, are automatically retrieved upon connecting to the unit.
Individual cylinder adjustment - All PCIII USB units have a "cylinder trim" adjustment feature that allows you to "offset" fuel to one or more cylinders. Additionally, for advanced users, the PCIII USB allows individual cylinder mapping. Now each cylinder can be mapped individually throughout the entire rpm/throttle position range.
Enhanced "file compare" utility - The PCIII USB software allows you to compare two map files without the Power Commander connected. There is a numerical display as well as a brand new graphical display.
Easier to use "button adjustment" mode - The button adjustment has been made easier by introducing a "startup delay". This lets the user have enough time to start the bike and then switch the PCIII USB into "button adjust" mode. The ranges of the buttons are now displayed in the software. Simply connect the unit to the computer and press one of the buttons. Their ranges are shown on the screen.
"Expansion port" for upgrades and accessories - The "expansion port" allows easy connection of accessories such as our new ignition module, Quick shifter, Multifunction Hub, Pressure Sensor display and LCD display unit. Automatic map retrieval upon connection - As soon as you connect the PCIII USB to the computer and launch the software, the map installed in the PCIII USB will be displayed.
